> Best inexpensive header, suggestions?
Brando
post Feb 29 2008, 05:26 PM
BUY MY SPARE KIDNEY!!!
I can't plop down the $1k+ for a tangerine, so I need some direction on an inexpensive, durable (read: wont rust like madness), clean (read: won't leak so I can fab up heat). I'm not sure what a decent one will cost... Definitely looking for a boost over SSI's in performance.
My guesses are...
Euro-Race
Kerry Hunter
thanks for your input.
purple
post Mar 4 2008, 10:48 PM
Pigeon feeders attract me
whelp, I found some 12ga (IMG:style_emoticons/default/happy11.gif) galvanized steel strip at lowe's and got a grade 8 bolt and some nuts and went to town.
I had to pull really hard to get the heat sleeve un-melted from the clutch cable and I have to run the clutch cable underneath the engine mount bar, but i duplicated what racer chris did and it works beautifully! If i'd run the clutch thru the mount bar, it would still be all on the header.
As a side note, i also fixed my timing and synched my carbs tonight too. talk about getting a lot of stuff done!
eurorace...FTW! (IMG:style_emoticons/default/driving.gif)
VaccaRabite
post Mar 5 2008, 01:08 PM
En Garde!
QUOTE(purple @ Mar 4 2008, 11:48 PM) *
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Cause I am probably going to have to do the same thing, now that I have been scared off the header wrap.
How long is the piece of metal used to offset the cable pully?
Zach
Brando   Best inexpensive header   Feb 29 2008, 05:26 PM
dr914@autoatlanta.com   I can't plop down the $1k+ for a tangeri...   Feb 29 2008, 05:34 PM
Brando   Sweet. If I ever go six, I can use an MSDS header ...   Feb 29 2008, 10:01 PM
Maltese Falcon   Sweet. If I ever go six, I can use an MSDS header...   Mar 1 2008, 04:57 PM
lotus_65   Sweet. If I ever go six, I can use an MSDS heade...   Mar 4 2008, 05:30 AM
Vacca Rabite   Brando, the T-4 race header that we build is ONL...   Mar 4 2008, 07:48 AM
lotus_65   [quote name='lotus_65' post='1004689' date='Mar 4...   Mar 4 2008, 08:02 PM
Phoenix 914-6GT   http://www.triadwestperformance.com/   Mar 1 2008, 11:20 AM
Brando   Thanks Marty, I greatly appreciate your reply. I s...   Mar 2 2008, 09:26 PM
Maltese Falcon   [quote name='Brando' post='1004233' date='Mar 2 20...   Mar 3 2008, 08:59 PM
purple   I have a eurorace header and it sounds very nice. ...   Mar 3 2008, 07:47 AM
Vacca Rabite   I have a eurorace header and it sounds very nice....   Mar 3 2008, 09:57 AM
purple   I have a eurorace header and it sounds very nice...   Mar 3 2008, 12:09 PM
jasons   Did you put header wrap on the header, or a ther...   Mar 3 2008, 05:34 PM
Racer Chris   One way to help the cable clear the header:   Mar 3 2008, 05:08 PM
purple   One way to help the cable clear the header: Int...   Mar 3 2008, 08:28 PM
Racer Chris   One way to help the cable clear the header: In...   Mar 4 2008, 08:43 AM
purple   [quote name='purple' post='1004596' date='Mar 3 2...   Mar 4 2008, 09:19 AM
purple   hold on...13ga sheet metal? as in .0897 inches thi...   Mar 4 2008, 05:26 PM
jd74914   hold on...13ga sheet metal? as in .0897 inches th...   Mar 4 2008, 08:19 PM
Vacca Rabite   as sheet metal goes, 13 gauge is kinda thick. You...   Mar 4 2008, 05:28 PM
purple   whelp, I found some 12ga :evilgrin: galvanized st...   Mar 4 2008, 10:48 PM
Vacca Rabite   whelp, I found some 12ga :evilgrin: galvanized s...   Mar 5 2008, 01:08 PM
Racer Chris   The ones I supply with my headers have the bolt ho...   Mar 5 2008, 02:51 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:05 PM
