jd66921 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 ![]() |
Hi,
I recently started autocrossing my 914. I enjoy it a lot! The car is not really set up for autcrossing, no sway bars, standard alignment, etc, but it is still fun to see what I can do. The tires I am running are Kuhmo street tires. I know they are not optimal, but I am not ready to upgrade. The issue is trying to optimize tire pressure. I know the 914 is a very light car and therefore may not need a lot of pressure. I ran them originally at 35 psi. That seemed okay. I ran them up to 40 psi, and while fun to slide around, it was way too much! I am now running 32 psi, and I don't know if I should go lower or not. How does the pressure vs cornering curve go? I would think the cornering force would increase with tire pressure up to a point, and then tail off. Any ideas what the range should be? 25-35 psi? Higher? Lower? I'm just looking for general guidelines. Tires are 195/50's on 5.5 inch fronts and 6 inch rears at the moment. Thanks, Jeff PS: Autocross video |
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
Stock pressure, under "heavy load" is 29F/R. In my old 914, I ran 30/32 or 30/30 F/R depending on course layout.
You might start by "chalking" the tire. Mark where the Tread meets the shoulder. If after the run all the chalk is worn off, add pressure. If its all still there, lower pressure. You should have some type of wear mark on the tire to help show how much "rollover" the tire is doing. Realize too that pressures will change a bit with temp. Once you find a pressure that works for you, you may need to "add some" in the cold morning but let some out as your runs progress. Hope this helps! |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Stock pressure, under "heavy load" is 29F/R. In my old 914, I ran 30/32 or 30/30 F/R depending on course layout. You might start by "chalking" the tire. Mark where the Tread meets the shoulder. If after the run all the chalk is worn off, add pressure. If its all still there, lower pressure. You should have some type of wear mark on the tire to help show how much "rollover" the tire is doing. Realize too that pressures will change a bit with temp. Once you find a pressure that works for you, you may need to "add some" in the cold morning but let some out as your runs progress. Hope this helps! Stock pressure? It veries by tire. DOT recomends 32 PSI for the street, but when racing there is no stock pressure. My RA-1's run at a very different pressure than my V-710s. Joe's advice was very good. Follow what he said and keep a close eye on how far the tire is rolling to the side.You want a little but too much can be very bad. |
Lo-Fi Version | Time is now: 6th July 2025 - 09:13 PM |
