Crankcase breather with carbs., How do you attach a hose to the filters? |
Thack |
Nov 11 2007, 11:32 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
So.Cal.914 |
Mar 6 2008, 11:20 AM
I don't know if this is the case for sure, and I know i'll be corrected if not. I have
heard that the 1.8 needs to have the oil filler cap seal in working condition, if it leaks, it can cause the engine to run shitty. Sooo it makes me think, that with FI, you would not want to have a oil filler cap seal in working order and yet a big hole in your head. (connected) I am pretty sure you are missing the tube in that 2.0 head. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 06:23 PM |
