| kyhunting |
Feb 25 2008, 05:05 PM
Newbie ![]() Group: Members Posts: 14 Joined: 8-October 07 From: KY Member No.: 8,199 |
Has anyone used the Tilton Floor Mount Pedals? If so do you have pictures?
| PeeGreen 914 |
Mar 7 2008, 05:32 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
Now you have me thinking I should give this a try. What did you use for a slave? What was it off of?
Do you have any pictures of your work? |
| byndbad914 |
Mar 9 2008, 12:16 PM
shoehorn and some butter - it fits ![]() ![]() ![]() Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Now you have me thinking I should give this a try. What did you use for a slave? What was it off of? Do you have any pictures of your work? sorry for the late response... was loading the trailer F and racing yesterday. I had the assembly in the "old" configuration (when it was still a full stock tub) and have a couple pix that show what it looked like but nothing with great detail. I made an aluminum plate to "flatten" the floor (the pedal box area "sinks" down), made some spacers to fit in the sunken area to support the plate and bolted it down. Now the floor was essentially flat. Then I mounted the pedal assembly to my alum plate with the short master cyls right against the firewall. The slave cyl I used was a standard Wilwood brand slave unit and it is still working in the car just fine as of yesterday. Here are my old pics ![]() you can see I had rigged up a brake light switch with the original switch just to get the car legal again. Shortly after this pic I added an inline pressure switch to operate the brake lights (you can get them from Summit... IIRC mine is a Painless Wiring brand) The slave - I bent the rod end immediately cuz I have a Kennedy clutch setup for the V8 that is fricken brutal so I simply used an angle-iron steel bracket in place of the setup you see here and it worked perfectly. I machined up a piece of box steel to slip-fit over the old 930 bracket and had it professionally welded ![]() |
| PeeGreen 914 |
Mar 9 2008, 02:08 PM
Now you have me thinking I should give this a try. What did you use for a slave? What was it off of? Do you have any pictures of your work? sorry for the late response... was loading the trailer F and racing yesterday. I had the assembly in the "old" configuration (when it was still a full stock tub) and have a couple pix that show what it looked like but nothing with great detail. I made an aluminum plate to "flatten" the floor (the pedal box area "sinks" down), made some spacers to fit in the sunken area to support the plate and bolted it down. Now the floor was essentially flat. Then I mounted the pedal assembly to my alum plate with the short master cyls right against the firewall. The slave cyl I used was a standard Wilwood brand slave unit and it is still working in the car just fine as of yesterday. Here are my old pics ![]() you can see I had rigged up a brake light switch with the original switch just to get the car legal again. Shortly after this pic I added an inline pressure switch to operate the brake lights (you can get them from Summit... IIRC mine is a Painless Wiring brand) The slave - I bent the rod end immediately cuz I have a Kennedy clutch setup for the V8 that is fricken brutal so I simply used an angle-iron steel bracket in place of the setup you see here and it worked perfectly. I machined up a piece of box steel to slip-fit over the old 930 bracket and had it professionally welded ![]() So if I were to ask you everything I would need to order to do this do you happen to have a list of al the parts needed? I thank you for all the time you've taken already. This could be great for completing my race car. Oh, how is the throttle handled? |
kyhunting Tilton Floor Mount Pedals Feb 25 2008, 05:05 PM
jd74914 This question should be in the garage. It would ge... Feb 25 2008, 10:30 PM
:agree: Mar 5 2008, 06:45 PM
dakotaewing fagafsbg Mar 5 2008, 08:54 PM
LarryR
fagafsbg
SWEET! I hate to ask how much do a... Mar 5 2008, 09:20 PM
charliew
fagafsbg
Hey Thom, Thats a nice pedal fitup, lo... Mar 7 2008, 10:29 AM
dakotaewing
fagafsbg
Hey Thom, Thats a nice pedal fitup, l... Mar 8 2008, 12:18 AM
retrofit
fagafsbg
:Qarl: This is awesome. Great for any... Mar 9 2008, 12:34 PM
byndbad914
:Qarl: This is awesome. Great for anyone 5... Mar 9 2008, 04:21 PM
dakotaewing Right Hand Drive Mar 5 2008, 08:59 PM
dakotaewing $468 at Summit Mar 5 2008, 11:33 PM
byndbad914
$468 at Summit
with master cyls an all I ha... Mar 6 2008, 08:47 PM
dakotaewing $2169 at HRP.com Mar 5 2008, 11:35 PM
sww914 They're really cool. When I build a 914 for my... Mar 5 2008, 11:42 PM
tdgray
They're really cool. When I build a 914 for m... Mar 6 2008, 03:26 PM
sww914 Oh, my son's funny too! :D :D :D Mar 6 2008, 04:25 PM
Phoenix 914-6GT So how would you do a plantation kit on a 901? Can... Mar 7 2008, 01:00 PM
byndbad914
Can you even put a slave on a 901?
I have a 930 s... Mar 7 2008, 05:20 PM
Phoenix 914-6GT :beer2: Sweet. Thanks for the info. I think I will... Mar 10 2008, 01:15 AM
byndbad914 no problem. If you need something, just PM me so ... Mar 10 2008, 01:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:24 AM |
