Koni Sport coilover kit with threaded perches, now installed. Need Mt. View alignment shop info |
Michael N |
Mar 11 2008, 10:48 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I am getting ready to install Koni sports with a Rebel Racing 2.25" ID spring coilover kit. I have Eibach 8" 200lbs springs to go with the set up. Using the search function I see that most coilover kits with the threaded perches are using 10" springs. Will the 8" springs I have still give me the same results by adjusting the collar?
Attached thumbnail(s) |
db9146 |
Mar 12 2008, 07:41 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I have not installed the coil-over front suspension on mine yet but I believe from the research I've done that most of the time, 8" springs are also run with helper springs - most times with a rate less than the main (8") spring.
Lo-Fi Version | Time is now: 16th June 2024 - 08:04 AM |
