> SDS VS MS, I would like to figure this one out??????
toon1
post Mar 16 2008, 01:11 PM
DISCLAIMER: This is not a thread to argue bash or to say yours is better than mine.
I would like to learn what the difference is!
I am an MS user and happy with it, if SDS will fuel an engine better, I would like to find out why!
I have been following Daves thread about MS not fueling his engine well enough. There are dyno results proving this, can they be posted with the reasons why MS fails to provide an engine with what it needs?
I have been to SDS's site and cannot find any reason why it would fuel an engine better.
Is it the simplicity of setup?
Is it that SDS has 16x16 fuel tables?
Is SDS's processor faster?
I'm sure if MS was capable of doing the same as SDS, Jake would have figured it out.
I would like to learn differences!
AGAIN, no bashing, just learning.
Keith
DNHunt
post Mar 17 2008, 08:42 AM
914 Wizard? No way. I got too much to learn.
I guess I would challenge the dyno results at least with my engine. MS never made it on the dyno.
Here's my take. None of the these knocks against MS are insurmountable but, they are potential pitfalls that aren't a concern with SDS.
I have some assembly issues. 1)MS is homemade and it depends on the skill of the assembler. 2)Solder flux is acidic and if not cleaned well the board will deteriorate.
Installation is realatively difficult because of the wide variety of applications and the number of options. This may be the biggest challenge. It was my wiring harness that let me down at Jake's.
Tuning is way out of control with MS. It can be daunting looking at all the menus. Some of the stuff is a crap shoot cause it's not explained well. Changes are made frequently as a lot of code is experimental.
If a person gets beyond all that MS will work just fine with 1 exception. The intake air temperature correction is almost impossible to get right because the tables are generated with only 3 entries. For people using MS check your AFR values with changes in IAT: I bet it will vary. There is a bandaid solution in the program which is a tunable 5 point table. So, on top of tuning all the other stuff one gets to tune out problems. The solution might be to use a GM sensor (that is what SDS uses) instead of a Bosch but, I don't know how that table was generated.
Granted, all this stuff can be overcome but, in my case I have a lot invested in my motor (and Jake and Charles may have more invested in it). After spending a morning troubleshooting no rpm signal to the MS board, I decided to go with something I could depend on so, I switched.
SDS is far simpler, it's easy to tune and the tune is stable with increasing temps.
Dave
agrump
post Mar 18 2008, 07:18 AM
QUOTE(DNHunt @ Mar 17 2008, 06:42 AM) *
I found that the stock Bosch sensor suffered from heat soak, after swapping it for a GM open cage sensor that problem disappeared. Now I'm only getting a very small change in AFR's based on air intake temps that seems somewhat random. On the other hand, I see a definite trend that AFR's get richer as the head temperatures increase. The clt (head sensor) isn't used by MS after warmup so I have no idea why it is happening. I don't know if the SDS system has the same problem.
Mark Henry
post Mar 18 2008, 07:59 AM
that's what I do!
QUOTE(agrump @ Mar 18 2008, 09:18 AM) *
No SDS doesn't have any head temp/heat soak issues. It uses std. bosch head temp sender, same as in the stock L or d-jet. On my wideband A/F values are rock soild were I set them 12.5 to 13:1, my old cammed 2.0 and stock 1.8 had/have head temps just barely over 300F.
I've had no tuning issues, in fact when I sold my 2.0 and stuck in my stock 1.8 it took me only about 10-15min to change my map and tune, as I drove alone by myself. Try doing that with any other system.
BTW I then took the programmer and WB out of the car and drove 2 seasons without ever looking at my WB, no problems.
Just looking at that table gives me a headache...and that's not even the map. Too much information.
BTW I got the upgrade chip kit for my 4F, so now I'll be able to datalog and see my WB values with my fuel value.
agrump
post Mar 18 2008, 09:35 AM
Hell, if I set up my maps as 12.5 I wouldn't notice it either, but at 15-16 cruise it starts to stand out as an oddity.
Mark Henry
post Mar 18 2008, 10:27 AM
that's what I do!
QUOTE(agrump @ Mar 18 2008, 11:35 AM) *
I can do that, but on a T4 you can watch the head temps climb fast as soon as you start lean it out a cruise. Best I've hit is about 14:1 without the temps getting up there.
I can say for sure that's your heat soak issue and if you keep doing it it will waste your engine.
Your system and WB is only part of the package, you need to know your head and oil temps as well. This is not an option.
Jake, it's the 44's or SDS...never said anything different....I don't have time to waste on messing with anything else. Time is money.
toon1   SDS VS MS   Mar 16 2008, 01:11 PM
banger   I think that megasquirt is a great system, but in ...   Mar 16 2008, 02:12 PM
yarin   To summarize, both systems will exceed your needs....   Mar 16 2008, 02:37 PM
Mark Henry   I wouldn't call SDS plug 'n play. Might be...   Mar 16 2008, 05:10 PM
ottox914   See my sig for SDS install thread. I went that way...   Mar 16 2008, 08:35 PM
DNHunt   I guess I would challenge the dyno results at leas...   Mar 17 2008, 08:42 AM
ws91420   2)Solder flux is acidic and if not cleaned well ...   Mar 17 2008, 01:54 PM
agrump   If a person gets beyond all that MS will work ju...   Mar 18 2008, 07:18 AM
Mark Henry   [quote name='DNHunt' post='1009504' date='Mar 17 ...   Mar 18 2008, 07:59 AM
agrump   Hell, if I set up my maps as 12.5 I wouldn't...   Mar 18 2008, 09:35 AM
Mark Henry   Hell, if I set up my maps as 12.5 I wouldn't...   Mar 18 2008, 10:27 AM
agrump   My CLT's run around 300 and oil just breaks ...   Mar 18 2008, 11:17 AM
yarin   Hey Dean, Can you please post your spark tables? ...   Mar 18 2008, 11:28 AM
agrump   Hey Dean, Can you please post your spark tables?...   Mar 18 2008, 12:12 PM
Mark Henry   One thing I would think about is how many aircraft...   Mar 17 2008, 09:29 AM
Jake Raby   I use SDS exclusively based on the user interface ...   Mar 17 2008, 10:19 AM
yarin   Yes that is correct. Standard temp for hobby/stand...   Mar 17 2008, 02:33 PM
Jake Raby   Correct. However people need to be informed th...   Mar 17 2008, 03:01 PM
yarin   Correct. However people need to be informed t...   Mar 18 2008, 06:32 AM
Mark Henry   That's the beauty of SDS, nothing to de-bug. I...   Mar 18 2008, 07:34 AM
Jake Raby   I'm trying talk a customer into going SDS on ...   Mar 18 2008, 09:07 AM
Rick_Eberle   Hey Dean, what software is that???   Mar 18 2008, 09:26 AM
agrump   Hey Dean, what software is that??? Wrote it mys...   Mar 18 2008, 09:46 AM
jkeyzer   What was that recent post about stifling creativit...   Mar 18 2008, 10:37 AM
r_towle   Are you, Mark and Jake, confident enough to break ...   Mar 18 2008, 11:40 AM
George H.   Are you, Mark and Jake, confident enough to break...   Mar 18 2008, 12:13 PM
brer   see my sig and contribute maybe? :)   Mar 18 2008, 12:02 PM
yarin   Thanks for posting your table dean. When you get a...   Mar 18 2008, 12:44 PM
Jake Raby   FWIW, Ross from SDS will be teaming up with me to ...   Mar 18 2008, 12:50 PM
Mark Henry   Are you, Mark and Jake, confident enough to break...   Mar 18 2008, 01:00 PM
r_towle   Are you, Mark and Jake, confident enough to brea...   Mar 18 2008, 02:26 PM
JmuRiz   From what I've read here is sounds like SDS is...   Mar 18 2008, 01:18 PM
Mark Henry   From what I've read here is sounds like SDS i...   Mar 18 2008, 01:29 PM
JmuRiz   From what I've read here is sounds like SDS ...   Mar 19 2008, 09:36 AM
Mark Henry   [quote name='Mark Henry' post='1010038' date='Mar...   Mar 19 2008, 02:02 PM
McMark   When I hear/read these discussions, I can't he...   Mar 18 2008, 04:04 PM
toon1   I will blow the whistle and say "a...   Mar 18 2008, 04:12 PM
agrump   Let's not forget some of the extra features th...   Mar 19 2008, 05:38 AM
DNHunt   Dean Those items are only advantages if you need ...   Mar 19 2008, 06:27 AM
Jake Raby   I believe that most of the things that MS uses as ...   Mar 19 2008, 07:21 AM
Mark Henry   Yep we could argue this till blue in the face, not...   Mar 19 2008, 07:26 AM
brer   :chair:   Mar 19 2008, 10:17 AM
brp986s   does anyone here know if you can use sds on a 911 ...   Mar 19 2008, 10:38 AM
Jake Raby   Been driving one daily for 5 years... Thats ever...   Mar 19 2008, 11:08 AM
Rick_Eberle   ... since then I haven't touched the program...   Mar 22 2008, 06:36 PM
Rand   I'm surprised that Pinz doesn't have a Mas...   Mar 19 2008, 11:18 AM
Jake Raby   The TIV isn't heavy duty enough for the Pinz. ...   Mar 19 2008, 12:10 PM
JmuRiz   See Jake has the idea, I'd like to do the same...   Mar 19 2008, 02:06 PM
Jake Raby   I'd like to find a mid 70s Benz vert myself, r...   Mar 19 2008, 02:54 PM
JmuRiz   I'd like to find a mid 70s Benz vert myself, ...   Mar 21 2008, 12:50 PM
Jake Raby   Yeah a 450 or 500SL is what I'd like to find.....   Mar 21 2008, 02:15 PM
crash914   I used to have a '72 450 slc... great car...   Mar 21 2008, 03:19 PM
McMark   There's a difference between these two: 1.) A...   Mar 22 2008, 02:01 AM
toon1   The real intention of this post was to usderstand ...   Mar 22 2008, 09:52 AM
Jeff Bowlsby   Why is MS considered " experimental"....   Mar 22 2008, 10:14 AM
Jake Raby   I do believe that MS has its place and I believe t...   Mar 22 2008, 10:56 AM
Jake Raby   Yes, but earlier versions of the SDS (pre V16.6) o...   Mar 22 2008, 07:20 PM
Rick_Eberle   I think I get it now... The AFR table is burned in...   Mar 22 2008, 07:42 PM
toon1   Yes, but earlier versions of the SDS (pre V16.6) ...   Mar 22 2008, 10:14 PM
Jake Raby   Every combo is slightly different and since I don...   Mar 23 2008, 09:20 AM
toon1   Every combo is slightly different and since I don...   Mar 23 2008, 09:42 AM
- Lo-Fi Version Time is now: 4th July 2025 - 08:47 PM
