I need to order viton push rod tube o-rings, and get the right parts the first time. |
Gint |
Mar 20 2008, 10:44 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I don't want to order parts today, find out next Tuesday afternoon when they arrive that I got the wrong parts without enough time to order the correct units and get them shipped before Saturday when I plan to do the work. I've heard too many stories right here on this board about folks ordering a set of push rod tube o-rings and only half being viton (green right?) and the other half being some other crap.
Or in other words, I want to order parts and expect to get the right parts the first time. Can anyone suggest a vendor that can perform that task? |
Jake Raby |
Mar 20 2008, 12:18 PM
Thanks. Installing these things daily gives us an edge for sure :-)
Most of the guys selling parts have never done an install of these items. That said I always recommend ordering a couple extra of each seal to use as "guinea pigs" to practice the install procedures. You can use a single pushrod tube with a seal on each end and install that tube assembly in each bore of the engine and then remove it to see if any surface imperfections cause a tear that WILL be an oil leak. This sort of "tests" the procedure and each bore at the same time and by the time you have installed that single tube assembly in each bore you'll have the feel necessary to do the job in "real time" without tearing a seal. I have installed these seals blindfolded and still not had an oil leak- I don't use Viton :-) |
Lo-Fi Version | Time is now: 16th June 2024 - 02:50 AM |
