fog lights, need help! |
mattp |
Mar 21 2008, 07:05 PM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
changed bumpers, went from square fogs to pilots, before making change I contacted wires to new fogs they worked, put it all together now nothing?
Cant tell where its shorting, anyone ever have this? |
Spoke |
Mar 22 2008, 01:33 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Makes sense that the whole car shorted and went dim. One of the terminals on the fog switch is the ground connection for the little light in the switch. One terminal powers the relay, and the other is the 12V feed from the ignition switch. With ignition on, the power to the fog light switch is directly from the battery with no fuse in the line. Dead short for sure.
The fog switch should have 12V on terminal 15. Terminal 31 is ground, and Terminal K is the switched 12V. Should be 0V with switch off, and 12V when fog switch is on AND ignition switch is on. If 12V on Terminal K, you should have 12V on Terminal 85 of the relay should be 12V also. Terminal 30 on the relay is 12V feed for lights. Terminal 87 on the relay is 12V switched to lights. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:14 PM |
