Acronym list...can you add to it? |
Joe Bob |
Dec 24 2003, 05:09 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
AAV = All Activity Vehicle
ABD = Automatic Braking Differential ABS = Anti-lock Brake System ACC = Automatic Climate Control AFAIK = As Far As I Know ASR = Acceleration Slip Reduction ATF = Automatic Transmission Fluid BAS = Braking Assist System BTDT = Been There, Done That BTW = By The Way CAN = Controller Area Network CAT = Catalytic Converter CDI = Common (Rail) Direct Injection CIS = Continuous Injection System CO = Carbon Monoxide DAPO= Dumb *ss Previous Owner DI = Direct Injection DIY = Do It Yourself DME = Digital Motor Electronics (DME) engine-management system DK = Don't Know DOHC = Dual OverHead Cams DRL = Daytime Running Lights ESP = Electronic Stabilization Program (also 4-ESP on 4-wheel drive vehicles) ETR = Emergency Tensioning Retractors (seatbelt part) ETR = Evaporator Temperature Regulator (climate control part) ETS = Electronic Traction System (also 4-ETS on 4-wheel drive vehicles) FI = Fuel Injection FS = For Sale FSS = Flexible Service System (that little "wrench" light on the dash) FUBAR = "Fouled" Up Beyond All Repair FWIW = For What It's Worth FWD = Front Wheel Drive FYI = For Your Information HC = HydroCarbons HFM = Hot-Film Mass-airflow (sensor) HP = Horse Power HTH = Hope This Helps HTML = HyperText Markup Language (forbidden on this list!) HTTP = HyperText Transfer Protocol HVAC = Heating, Ventilation, & Air Conditioning IANAL = I Am Not A Lawyer (usually followed by "but" and a legal opinion) IAW = In Accordance With IMHO = In My Humble Opinion IMNSHO = In My Not So Humble Opinion IMO = In My Opinion IOW = In Other Words IP = Injection Pump LMAO = Laughing My A$$ Off LOL = Laughing Out Loud LSD = Limited Slip Differential MFI = Mechanical Fuel Injection NLA = No Longer Available NOS = New Old Stock NOx = Oxides of Nitrogen OE = Original Equipment OEM = Original Equipment Manufacturer OBD = On-Board Diagnostics OD = Outside Diameter OTOH = On The Other Hand PITA = Pain In The -- well, you know... PO = Previous Owner PM = Preventive Maintenance PS = Power Steering RKE = Remote Keyless Entry ROTFL = Rolling On The Floor, Laughing ROTFLMAO = Rolling On The Floor, Laughing My A$$ Off RTFM = Read The "Funny" Manual RTM = Read The Manual S/B = Should Be SNAFU = Situation Normal, All "Fouled" Up SOHC = Single OverHead Cam SRS = Supplemental Restraint System (airbags & belt tensioners) SUV = Sport Utility Vehicle TIA = Thanks In Advance TDC = Top Dead Center TDM = Technical Data Manual TO = Trap Oxidizer TSB = Technical Service Bulletin TTO= Trailing Throttle Oversteer (Newbies need to be aware of that one!) TTYL = Talk (or Type) To You Later URL = Uniform Resource Locator (website address) VBG = Very Big Grin VIN = Vehicle Identification Number WOB = Waste of Bandwidth (a message that's irrelevant) WRT = With Regards To WTB = Want To Buy WTG = Way To Go! WX = Weather YMMV = Your Mileage May Vary And what about :-) and , you ask? Because there's no eye contact or voice intonation in e-mail, it's sometimes helpful to punctuate messages with textual emoticons known as "smileys." A smiley can clarify the writer's intention when it might otherwise be misinterpreted. The semicolon-hyphen-close parenthesis combination at the end of this paragraph is a wink. Tilt your head towards your left shoulder and you'll see a little "smiley face" with its right eye winking. I know it's a pain in the neck, but it's better than making enemies because someone took something you wrote *too* seriously. ;-) There are literally hundreds of smileys, but here's a short list of the most common ones. Some people use them more than others, but most people use them occasionally. :-) Smile ;-) Wink :-D Laughing, big smile :-( Frown :-\ Chagrin, puzzlement :-P Sticking out tongue :-* Kiss |
eresener |
Dec 25 2003, 12:52 PM
Dr. Sawsall Group: Members Posts: 218 Joined: 17-October 03 From: Missouri Member No.: 1,252 |
ESAD=Eat sh*t and Die
Lo-Fi Version | Time is now: 29th May 2024 - 03:17 AM |
