> AX transmission
r_towle
post Mar 15 2003, 05:24 PM
Custom Member
So,
I want to stop shifting so much at the Autocross.
What gears would you all recommend???
Rich
Brad Roberts
post Mar 20 2003, 11:10 AM
914 Freak!
Oh,
we chat about this like it is nothing. NONE of this is easy. Plenty of physical work to get 5th off the pinion shaft. We are leaving out about 150 steps in the process.
B
r_towle   AX transmission   Mar 15 2003, 05:24 PM
ChrisReale   Not a professional answer (ill leave that to the "...   Mar 15 2003, 06:15 PM
Zeke   In that case, Chris, I think you're friend has...   Mar 15 2003, 06:42 PM
J P Stein   I would like an A or B first. We are pretty much S...   Mar 15 2003, 07:57 PM
ChrisReale   Zeke, he IS going faster than me, by about ten f...   Mar 15 2003, 08:50 PM
J P Stein   <...   Mar 19 2003, 08:33 PM
porsche735   Rich, As I said, no gears to buy. All you do is m...   Mar 19 2003, 09:24 PM
Brad Roberts   I normally use the terms (Drive and Driven gears) ...   Mar 19 2003, 09:35 PM
Brad Roberts   Richard, We flip 5th gear to make a new shorter 3...   Mar 19 2003, 10:52 PM
Mike T
  Mar 20 2003, 08:19 AM
drew365   This sounds like a good mod for a short road cours...   Mar 20 2003, 09:46 AM
Joseph Mills   I've been given two spare trannys from an ex-r...   Mar 20 2003, 10:18 AM
Brad Roberts   Joseph. Flip a 5th from the tranny you want to us...   Mar 20 2003, 11:08 AM
Brad Roberts   Oh, we chat about this like it is nothing. NONE o...   Mar 20 2003, 11:10 AM
James Adams   Gear chart for about a stock diameter tire (calcul...   Mar 20 2003, 11:19 AM
Zeke
  Mar 20 2003, 12:51 PM
Travis Neff   So, for a hot street setup - you would want to obt...   Mar 20 2003, 01:19 PM
TimT   Brad I took the liberty to play with the pic yo...   Mar 20 2003, 03:58 PM
TimT   oops helps to attach the pic   Mar 20 2003, 04:03 PM
Zeke   I just did this and that's exactly what it loo...   Mar 20 2003, 04:31 PM
bpick84   It will run okay in reverse cut, but it may whine ...   Mar 21 2003, 09:35 AM
Zeke   No one is gonna explain to me what "delta" is (I t...   Mar 21 2003, 10:46 AM
Mueller   3.09-1.89=1.2 1.2/3.09=39% differance (delta) 1.8...   Mar 21 2003, 11:13 AM
Demick   I think the picture in Tim's post above shows ...   Mar 21 2003, 12:04 PM
Brad Roberts   Bill Pickering ?? If that is you... welcome. Thank...   Mar 21 2003, 12:17 PM
r_towle   I am close to understanding this...please forgive ...   Mar 21 2003, 05:33 PM
TimT
  Mar 21 2003, 05:38 PM
Zeke   <...   Mar 21 2003, 05:53 PM
Demick   Rich Drive gears are always on the input shaft, d...   Mar 21 2003, 06:05 PM
Brad Roberts   It wasnt designed for it, but I personally have be...   Mar 21 2003, 06:22 PM
TimT   I wondered about the thrust issue. Then being an e...   Mar 21 2003, 06:38 PM
porsche735   Back to this stock 5th thing.... Why would you wa...   Mar 21 2003, 07:08 PM
TimT   Milt did you get that spreadsheet I sent your way...   Mar 21 2003, 07:24 PM
Racer Chris     Mar 21 2003, 11:17 PM
Brad Roberts   Chris, The thread started out as a AUTOX thread.....   Mar 21 2003, 11:49 PM
TimT   Chris, I just bought the GT4 car, havent turned a ...   Mar 22 2003, 08:31 AM
Racer Chris     Mar 22 2003, 05:29 PM
TimT   Chris I know your were teasing just wanted to use ...   Mar 22 2003, 06:28 PM
mskala   This may not apply to many, but for PCA AX in our ...   Mar 22 2003, 06:57 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:26 AM
