Put my Tarett bar together last night and..., I got some ?'s |
Dave Cawdrey |
Mar 20 2003, 12:07 AM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Put it all together and need some answers.
1st: I didnt get any nylock nuts (6 needed) for mounting the bearing blocks to body. Easy fix but, shouldn't they come w/ the set up? 2nd: My car didnt have an existing bar and I need a template to locate the holes. Anyone have such a thing? TIA |
Dave Cawdrey |
Mar 20 2003, 01:54 PM
QUOTE(Ira Ramin @ Mar 20 2003, 07:55 AM) Korijo, I’m a little unsure about what your actual situation is but I’ll try to help out. If your car has the factory mounting features, you can mount directly to them. The only mod required is to open up the large hole in the middle for the larger swaybar to fit through. There will be nuts and a plate welded on the inside, so no additional hardware is required. If you don’t have the factory mounting, you will need a set of adaptor nut plates for the inside of the well. Tapping the sheetmetal or simply adding nuts on the inside will not hold for long, even with washers under them. Let me know if you need the nut plates. This link includes instructions for the nut plate. http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm Ira I'll need some nut plates, Ira... got some? |
Lo-Fi Version | Time is now: 8th June 2024 - 01:55 AM |
