QUOTE(Matt914MI @ Mar 19 2003, 10:28 PM)
You shouldn't tap the "hoes" you know. :P
Speaking of sway-bars, what size/grade nuts and bolts should I use on the factory mounts for a factory bar? The car originally had one, but I one of the POs sold it or something. So I have the holes there already, and I got mounts with the used bar I bought that seem to be fine, but I don't know if normal nuts and bolts would shake themselves loose. I have to order new bushings for it before I install it anyway, so should I order some special locknuts or something along with them? If so, where should I get them? Thanks guys.
-Matt
Nylock nuts are supplied with the Tarett. I can give you the torque numbers tommorow. I cant go to the garage right now, its almost past my bedtime
edit*****Brad you type too fast...plus you have a guest to entertain
