Car stalled unexpectedly, after a right turn, fuel filter? |
Andyrew |
Dec 26 2003, 07:10 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I just got finished with a nice ride around my block, like 5 times (IMG:style_emoticons/default/biggrin.gif), and I was on my way home and I just made a easy right hand turn and the car seemed to not get any fuel, it died, but it didnt stutter or anything, just slowly (matter of 3 seconds) died.. So I wait 10 seconds to think, and then check my little switch thingy (cant remember if I fliped it or not, I dont think so) for the fuel pump and then started right up..
Any idea's or am I just worried.. Andrew PS. Heater works, kinda... |
redshift |
Dec 26 2003, 07:29 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
My stalling turn check list:
Battery ground at chassis Tranny ground strap Wiring to relay box All wires to the coil When I had that problem, just as you described, I reterminated the end on my battery ground, cleaned all the relay sockets while I checked the terminations at the box, and took the tranny strap off, was perfect, the ends were dirty.. cleaned and reinstalled. All the wires on the coil were loose, I cleaned the contacts, and crimped them down. My battery ground was nearly bent out of the connector, because of the angle it was installed. My tach only 'bounces' when I downshift in a spirited fashion now. I found several problems, and fixed them all... I have no idea which problem caused it. (IMG:style_emoticons/default/smile.gif) Miles |
Lo-Fi Version | Time is now: 1st June 2024 - 04:15 AM |
