| smrz914 |
Dec 25 2003, 06:55 PM
Soon to be brightening the life of the person behind you. ![]() ![]() Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
So i took my t-stat out and put 3 1/8" holes in it. Anything i can/should chech while i'm in there?
| smrz914 |
Dec 28 2003, 08:55 PM
QUOTE You won't get all the air out the first time. I assume you followed the procedure I spelled out. I suggest doing the whole bleeding procedure one more time before moving on to something else. I did do it several times. QUOTE Did you see the bubbles completely go away at your fill point while engine was warming up? If you lower the level at that point about 1" and increase idle to about 1200-1500 or so, you will be able to run engine while water is expanding. I didn't get any bubbles at the fill point for any of the times I bled the system. QUOTE How old was that used radiator you installed? It could have pluggage. I have a new radiator. Speeking of this, when i rebuilt the motor there was some build up of "stuff" inside the engine and i cleaned it as best i could. I did have problems even with the original settings on the carb. I'll go through your list John and report what I find. |
smrz914 v8 t-stat Dec 25 2003, 06:55 PM
Brad Roberts Use a good Fel-Pro gasket (blue one that can be re... Dec 25 2003, 06:59 PM
smrz914
boxstr Paul Have you tried the thermostat that John Thoma... Dec 25 2003, 08:41 PM
John2kx Paul,
I saw your similar post over on porchev. I... Dec 25 2003, 08:51 PM
smrz914
boxstr Correct you are.
CCLIN914-8 Dec 25 2003, 09:59 PM
smrz914
rick 918-S When to temp gauge gets up to 260 does the cap rel... Dec 25 2003, 10:41 PM
Mueller blown head gasket???
Paul, I have a snap-on rad/c... Dec 25 2003, 10:55 PM
John2kx (QUOTE) My gauge shows above 260 and this is taken... Dec 25 2003, 10:59 PM
John2kx Sorry for the mess guys........this was my first a... Dec 25 2003, 11:05 PM
rick 918-S You can go back and edit out what you don't wa... Dec 25 2003, 11:07 PM
boxstr John You got your point across. Good job.
CCLIN914... Dec 25 2003, 11:24 PM
smrz914
smrz914
John2kx Paul,
It appears you have not been using the righ... Dec 26 2003, 12:07 AM
John2kx adf Dec 26 2003, 12:07 AM
John2kx I doubt your water pump impeller is slipping on sh... Dec 26 2003, 12:09 AM
John2kx let's try that again Dec 26 2003, 12:10 AM
smrz914
It's never been that high untill recently. I... Dec 26 2003, 12:29 AM
smrz914 Did i use to many quotes? quotes are not coming up... Dec 26 2003, 12:31 AM
steve@ottosvenice.com One way to make sure all the air is out of the sys... Dec 26 2003, 12:35 AM
smrz914 ok i'm moving the expantion tank and getting s... Dec 26 2003, 12:36 AM
John2kx Paul,
Since your car ran fine until recently, I w... Dec 26 2003, 03:39 AM
smrz914 John i've had 3 radiator caps in the car all a... Dec 26 2003, 04:59 PM
Brad Roberts Keep us up to date Paul. I was away from the compu... Dec 27 2003, 11:16 PM
smrz914 So I put the car back together and bled it without... Dec 28 2003, 07:34 PM
Brad Roberts Yes. Get the pressure checker from Mueller. Do you... Dec 28 2003, 07:42 PM
smrz914 Mueller i'm sending an e-mail...
Brad I have ... Dec 28 2003, 07:54 PM
Brad Roberts John pointed out that you need to get *some* heat ... Dec 28 2003, 07:56 PM
John2kx Paul,
I take it you test drove the car and still ... Dec 28 2003, 08:11 PM
Brad Roberts Hum.. he is measuring the water temp at its hottes... Dec 28 2003, 08:17 PM
smrz914
smrz914 I have to move the temp gauge pickup to the tip of... Dec 28 2003, 09:07 PM
John2kx Brad............I understood that his temp. probe ... Dec 28 2003, 11:10 PM
smrz914 I use to use a combination of bleeding from the pe... Dec 28 2003, 11:57 PM
Brad Roberts Depending on what fans you have mounted.. they can... Dec 29 2003, 12:01 AM
smrz914 It get's hot standing still as well. Doesn... Dec 29 2003, 12:07 AM
John2kx Paul,
As a reference, my fans turn on at 179.6F a... Dec 29 2003, 03:15 AM
smrz914 Oh it doesn't matter when the fans turn on it ... Dec 29 2003, 03:12 PM
smrz914 I checked the spark plugs and they look really goo... Dec 30 2003, 08:49 PM
John2kx Time to try another gage. Dec 31 2003, 02:18 AM
smrz914 what is the guage going to do? The car is boiling ... Dec 31 2003, 02:24 AM
Brad Roberts Paul,
where are you located ?? I need to deliver ... Dec 31 2003, 04:25 AM
John2kx Paul,
I didn't know you were boiling over....... Dec 31 2003, 10:34 AM
smrz914 brad- I'm in lafayette, east bay, close to wal... Jan 1 2004, 07:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 01:02 PM |
