Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
This is the one that goes under the coveted upper and side seals. It hides under that seal. Its where nose of the targa top slides into and provides an additional barrier.
Well after the 3rd try we finally got it right, took some re-tooling on the die to make it right, but the lower lip suck up against the edge nicely. I did not realize how bad mine really was until I removed it! Note you will need to take an sharp scissors or exacto knife to cut the notch for the center. It's just in the fin not all the way through. I used my old one as a guide, it took me about 2 minutes. $30 Thanks to all for your support. Attached image(s) ![]() ![]() ![]() ![]() |
budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
I'll take one too!
Lo-Fi Version | Time is now: 13th June 2024 - 06:22 AM |
