terrymason |
Member ![]() ![]() Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 ![]() |
The problem - The car will go very lean around 2500 rpm, as if the pump jets were too small.
History: New fuel pump (3.5 PSI to each carb) 55 idle jets 55 pump jets 140 main jets 175 air correctors These carbs are new to the car, and I'm trying to dial them in. The car is lean when I first start it (16 / 17 on my air / fuel gauge), but then levels out to a nice 14.7 idle when warmed up. While driving, I can give the car 20% or so of the pedal, and drive up to highway speeds nicely, but when I goose it, it will go very lean (18-22 on my gauge) followed by a series of backfires and loss of power. I started off with 35 pump jets, and have moved up to 55s, which appear to be the most popular around here. I've also adjusted the pump jet linkage, from the nut fully loosened, and moved it in as far as it would go before affecting the main throttle shaft (like 60 turns or something). What do you guys think, do I need 75 pump jets? |
type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
Its tough to find the right etubes, and they are expensive if you do. I found a place in the UK that had some but I think it was about 8 pounds per tube! The guy who sells dells on ebay in Italy (Alfa1750) was willing to exchange etubes but that means you won't have any for the weeks during shipping. You can always solder the holes shut assuming the etubes you have are close enough to the ones you want (can't remember the details, too lazy to flip back).
Why not just ream the 35s out to 50s? -Chris |
Lo-Fi Version | Time is now: 3rd July 2025 - 09:00 PM |
