> OT Cold water 12 volt air conditioner for the 914., Anyone tried this?
Elliot Cannon
post Apr 30 2008, 12:07 AM
Group: Retired Members
I researched these air conditioners on the internet and found they cost about $700 to buy. I thought I might try to make one myself. How hard could it be rite? I started with a closed loop water circulation system. It is powered by a 12 volt 2 amp pump with a gallon per minute output. I got it at the local RV parts store. Bent some 3/8 inch copper tubing to fit into an old cooler we have in the garage. Connected some 3/8 rubber hose and used a heat exchanger I bought at a flea market for $5. Filled it with water and tried to bleed out as much air as possible.
SLITS
post Apr 30 2008, 07:33 AM
"This Utah shit is HARSH!"
You should have bought Mike Zs' Cool Suit that was for sale at the Swap Meet .... that's the same system it used 'cept the ice water is pumped thru a lattice in the suit.
Now, paint it yellow.
Elliot Cannon   OT Cold water 12 volt air conditioner for the 914.   Apr 30 2008, 12:07 AM
Elliot Cannon   It fits into the cooler and the cooler is filled w...   Apr 30 2008, 12:09 AM
Elliot Cannon   I built a plenum and will use this blower to force...   Apr 30 2008, 12:10 AM
Elliot Cannon   I used a Shop Vac hose for ducting and I had a dou...   Apr 30 2008, 12:12 AM
Elliot Cannon   Here's the other side. I will also make a lon...   Apr 30 2008, 12:17 AM
sww914   Cool :D Idea!   Apr 30 2008, 12:17 AM
Sleepin   Pretty neat idea for alot of applications! I c...   Apr 30 2008, 12:23 AM
drive-ability   thats nice, I wonder how well it will work? I woul...   Apr 30 2008, 12:25 AM
Elliot Cannon   I know the concept works. You can google them and...   Apr 30 2008, 12:36 AM
So.Cal.914   "Go Gadgit Teener"! Can ya see Elli...   Apr 30 2008, 01:04 AM
GWN7   compact swamp cooler.... nice......add salt to the...   Apr 30 2008, 01:28 AM
Sleepin   Adding salt would do that. I remember making ice c...   Apr 30 2008, 02:54 AM
blitZ   Pretty slick and should work well. I have seen a ...   Apr 30 2008, 06:22 AM
johannes   fill it with liquid azote ;)   Apr 30 2008, 07:05 AM
SLITS   You should have bought Mike Zs' Cool Suit that...   Apr 30 2008, 07:33 AM
Cap'n Krusty   Is it just me, or is it really scary that "My...   Apr 30 2008, 09:27 AM
marks914   I am going to try this with my heat exchanger inst...   Apr 30 2008, 09:39 AM
Elliot Cannon   I am going to try this with my heat exchanger ins...   Apr 30 2008, 11:13 AM
marks914   You could probably run a bilge pump in the bottom ...   Apr 30 2008, 09:54 AM
MoveQik   Elliot has been flipping through the Sporty's ...   Apr 30 2008, 10:10 AM
So.Cal.914   Any air volume is good when over a hundred degrees...   Apr 30 2008, 10:18 AM
angerosa   That is way cool! I actually had I colleague a...   Apr 30 2008, 10:53 AM
Elliot Cannon   That is way cool! I actually had I colleague ...   Apr 30 2008, 11:20 AM
jasons   My guess is, there is some thermal dynamic formula...   Apr 30 2008, 11:09 AM
Aaron Cox   so thats what retired people do.... Spend money to...   Apr 30 2008, 11:47 AM
ClayPerrine   Nice idea.. but it seems like a lot of work for so...   Apr 30 2008, 11:56 AM
MoveQik   Did you ever consider putting an AC unit on the c...   Apr 30 2008, 12:40 PM
ClayPerrine   Did you ever consider putting an AC unit on the ...   Apr 30 2008, 03:03 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:11 PM
