| Elliot Cannon |
Apr 30 2008, 12:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I researched these air conditioners on the internet and found they cost about $700 to buy. I thought I might try to make one myself. How hard could it be rite? I started with a closed loop water circulation system. It is powered by a 12 volt 2 amp pump with a gallon per minute output. I got it at the local RV parts store. Bent some 3/8 inch copper tubing to fit into an old cooler we have in the garage. Connected some 3/8 rubber hose and used a heat exchanger I bought at a flea market for $5. Filled it with water and tried to bleed out as much air as possible.
| ClayPerrine |
Apr 30 2008, 11:56 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Nice idea.. but it seems like a lot of work for so little gain.
Did you ever consider putting an AC unit on the car??? (IMG:style_emoticons/default/poke.gif) Betty can just reach over and turn her AC on anytime, and it gets cool. Plus it helps pull the moisture out of the air on a rainy day, making the windshield stay clear. So much for the statement "You don't need AC in a 914.. just take the top off." that I have been hearing out of the Cali contingent for years. (IMG:style_emoticons/default/poke.gif) |
| MoveQik |
Apr 30 2008, 12:40 PM
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,667 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Speaking of which....did that guy in Hurst, TX ever come up with a turn key AC system for /6's? (IMG:style_emoticons/default/poke.gif) Summer is upon us here in AZ. |
| ClayPerrine |
Apr 30 2008, 03:03 PM
Speaking of which....did that guy in Hurst, TX ever come up with a turn key AC system for /6's? (IMG:style_emoticons/default/poke.gif) Summer is upon us here in AZ. It's on hold until I get some other things done at home. Gotta keep Betty happy. (IMG:style_emoticons/default/whip[1].gif) |
Elliot Cannon OT Cold water 12 volt air conditioner for the 914. Apr 30 2008, 12:07 AM
Elliot Cannon It fits into the cooler and the cooler is filled w... Apr 30 2008, 12:09 AM
Elliot Cannon I built a plenum and will use this blower to force... Apr 30 2008, 12:10 AM
Elliot Cannon I used a Shop Vac hose for ducting and I had a dou... Apr 30 2008, 12:12 AM
Elliot Cannon Here's the other side. I will also make a lon... Apr 30 2008, 12:17 AM
sww914 Cool :D Idea! Apr 30 2008, 12:17 AM
Sleepin Pretty neat idea for alot of applications! I c... Apr 30 2008, 12:23 AM
drive-ability thats nice, I wonder how well it will work? I woul... Apr 30 2008, 12:25 AM
Elliot Cannon I know the concept works. You can google them and... Apr 30 2008, 12:36 AM
So.Cal.914 "Go Gadgit Teener"!
Can ya see Elli... Apr 30 2008, 01:04 AM
GWN7 compact swamp cooler.... nice......add salt to the... Apr 30 2008, 01:28 AM
Sleepin Adding salt would do that. I remember making ice c... Apr 30 2008, 02:54 AM
blitZ Pretty slick and should work well. I have seen a ... Apr 30 2008, 06:22 AM
johannes fill it with liquid azote ;) Apr 30 2008, 07:05 AM
SLITS You should have bought Mike Zs' Cool Suit that... Apr 30 2008, 07:33 AM
Cap'n Krusty Is it just me, or is it really scary that "My... Apr 30 2008, 09:27 AM
marks914 I am going to try this with my heat exchanger inst... Apr 30 2008, 09:39 AM
Elliot Cannon
I am going to try this with my heat exchanger ins... Apr 30 2008, 11:13 AM
marks914 You could probably run a bilge pump in the bottom ... Apr 30 2008, 09:54 AM
MoveQik Elliot has been flipping through the Sporty's ... Apr 30 2008, 10:10 AM
So.Cal.914 Any air volume is good when over a hundred degrees... Apr 30 2008, 10:18 AM
angerosa That is way cool! I actually had I colleague a... Apr 30 2008, 10:53 AM
Elliot Cannon
That is way cool! I actually had I colleague ... Apr 30 2008, 11:20 AM
jasons My guess is, there is some thermal dynamic formula... Apr 30 2008, 11:09 AM
Aaron Cox so thats what retired people do.... Spend money to... Apr 30 2008, 11:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:10 PM |
