> 993 brakes?, Can I make them work?
MikeHall
post May 4 2008, 03:52 PM
Can I make 993 brakes work on a 911 suspended 914? If so would it be a bolt on or would i have to make custom brackets for the calipers to bolt up?
Mike
PRS914-6
post May 6 2008, 10:29 AM
Excellence Magazine Project 914 3.6
Group: Retired Members
Here you go.....993 on a 914.
For the front with 911 suspension (3.5") you can use a caliper adapter and some Wilwood rotors. A stock Fuchs will not typically fit, I had to use 951 front wheels.
For the rear, although I could have machined them to fit, I chose to install a new anchor plate to the arm. This way a new caliper can be bolted on without machining.
If you do big brakes, check the wheel fitment, needed MC size, etc. It's not a cheap or easy venture by the time you are done.
MikeHall   993 brakes?   May 4 2008, 03:52 PM
Bigbohr   You cannot just bolt these up to a 914/911. I have...   May 4 2008, 04:41 PM
MikeHall   Being the 993 brakes would require so much work to...   May 4 2008, 04:52 PM
Bigbohr   Actually, what 911 suspension do you have? If you ...   May 4 2008, 05:08 PM
Wilhelm   Not to be a thread stealer, but....... I'm tr...   May 4 2008, 05:57 PM
Bigbohr   Not to be a thread stealer, but....... I'm t...   May 4 2008, 06:08 PM
race914   Lots of good info here http://www.vehiclecraft.co...   May 4 2008, 06:36 PM
Jeff Hail   Can I make 993 brakes work on a 911 suspended 914...   May 4 2008, 06:53 PM
MikeHall   I dont have the suspension yet but it was later mo...   May 4 2008, 07:31 PM
Mark Henry   The old 914club....hope it's OK to say this......   May 4 2008, 08:30 PM
Eric_Shea   Not only can you say it... we'll even let yo...   May 4 2008, 09:09 PM
Mark Henry   Not only can you say it... we'll even let y...   May 5 2008, 05:52 PM
MikeHall   This 914 is getting a EG33 with WRX 5sp which is 2...   May 4 2008, 09:25 PM
ClayPerrine   I suggest that you get Boxster calipers. You can ...   May 4 2008, 09:52 PM
davep   A good resource on brakes: http://www.pelicanparts...   May 5 2008, 08:58 AM
davep   Mueller was the guy designing the 'billet hubs...   May 6 2008, 09:22 AM
PRS914-6   Here you go.....993 on a 914. For the front with ...   May 6 2008, 10:29 AM
Aaron Cox   with 3.5" struts... you can buy Adapters to p...   May 6 2008, 10:43 AM
PRS914-6   Don't forget, if you switch, you have the emer...   May 6 2008, 11:56 AM
MikeHall   I dont mind a job as I enjoy projects more than an...   May 6 2008, 02:46 PM
- Lo-Fi Version Time is now: 16th June 2024 - 10:00 PM
