Outer door seals 914 531 813 10 & 914 531 814 10, $70+ shipping |
Mikey914 |
Mar 2 2008, 11:50 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Price $66 + shipping
For those of you that have been following my reproductions of the seals you will know that I have shrived to be as close to factory as I can on my reproductions. This is one exception. In doing some research, I found the original to be a dense extruded foam rubber. While I can manufacture seals with identical material, I have made a deviation. Here's why: The extruded foam rubber is actually porous and can trap water. Now I know why most all 914's I've seen have some rust in the lower door channels. I have selected a soft marine grade solid rubber to tool up for. This will provide a seal that will not trap and retain water. I will have these on line in about 4-6 weeks (maybe less). Let me know if you would like to be put on the list. Attached is a close up of the factory seal (on the right), you can see how it is sponge like, and can hold water. On the right is my seal. It is solid soft marine grade rubber. It is about the same hardness as the factory, only slightly harder (you may not even notice). Nice fit, just like factory. I had to brighten the photo so you could see the difference, so the picture isn't great, but you really can see the difference. Thanks, Mark Attached image(s) |
914werke |
May 9 2008, 12:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,120 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Mike got mine as well (IMG:style_emoticons/default/smile.gif)
On the outers, they will need to be trimmed for length? And the seal curves towards the cab or towards the world? |
Mikey914 |
May 10 2008, 03:00 AM
Mike got mine as well (IMG:style_emoticons/default/smile.gif) On the outers, they will need to be trimmed for length? And the seal curves towards the cab or towards the world? I've attached a picture of the drivers door by the handle. The "fin" comes oout from the door. I think you really can only put these in one way. I would start from the upper front where it bumps into the triangle window seal, and work my way to the back by the handle and trimming it there. Let me know if you have any more questions. -Mark Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:21 PM |
