| jim_hoyland |
May 13 2008, 03:52 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,101 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I have a nearly stock 1.8 L-Jet with all the smog controls removed. The l-Jet distributer is the dual vacumn type- both hoses attach to the throttle body.
Last two times the vacumn wimped out, I replcaed the can. I'm wondering if there is a better way to go- given I'm not running smog controls. Are there issues specific to the 1.8 L-Jet ? Thanks, jim Attached image(s)
| Brando |
May 13 2008, 05:18 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Jim,
The Mallory Unilite should work... Until then, run the stock distributor without the vacuum advance (it has too much inherently). Plug the ports on the throttle body. Re-time the car to 28ยบ total advance at 3500 rpms. That's how I timed mine with the L-Jet. If you run a Hyfire VI/A you need either one of the two tach adapters available. If you need a hand, bring the car by Skline's and I'll help you out with it. |
jim_hoyland Distributer replacement for 1.8 L Jet ? May 13 2008, 03:52 PM
r_towle Get a Mallory Unilite from Jake all setup with the... May 13 2008, 04:45 PM
ejm
Get a Mallory Unilite from Jake all setup with th... May 13 2008, 05:55 PM
ClayPerrine
Jim,
Until th... May 14 2008, 10:08 PM
jim_hoyland Thanks. Is there a fitment issue when replacing th... May 13 2008, 06:45 PM
ejm Drops right in. The ignition cable boot might make... May 13 2008, 06:51 PM
jim_hoyland What is the part number ? May 13 2008, 10:26 PM
Dave_Darling Don't you have to take a BFH to the engine tin... May 13 2008, 10:38 PM
Rav914
Don't you have to take a BFH to the engine ti... May 14 2008, 12:15 AM
jim_hoyland
Don't you have to take a BFH to the engine t... May 14 2008, 05:33 PM
Jake Raby we no longer carry the Mallory.
Too many idiots h... May 14 2008, 12:11 PM
ericread
Too many idiots ... May 14 2008, 12:14 PM
ejm I've installed them in engines using 1.7/1.8 t... May 14 2008, 06:22 PM
jim_hoyland I went to the Summitracing Web site:
http://store... May 14 2008, 09:56 PM
jim_hoyland One last question: can the Pertronix is used too ? Jun 12 2008, 08:19 PM
jim_hoyland Update:
Had the Mallory Unilite installed Monday ... Oct 15 2008, 09:41 PM
bfrymire
Update:
Had the Mallory Unilite installed Monday... Oct 15 2008, 09:51 PM
jim_hoyland
Update:
Had the Mallory Unilite installed Monda... Oct 15 2008, 09:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th July 2026 - 02:14 AM |
