Front caliper dragging? |
Wanna9146 |
May 13 2008, 09:28 PM
Member Group: Members Posts: 235 Joined: 19-January 08 From: Florida Member No.: 8,595 Region Association: South East States |
I just rebuilt my front calipers, including new pads. Have yet to re-fill/bleed.
On one side, the hub/rotor spins freely with only slight rubbing of the pads. Feels "normal" as compared to other cars I've worked on. On the opposite side, the hub/rotor does not spin freely. It spins only with some effort. Both rotors measure the same thickness (a little under 10mm). Will this issue fix itself once I re-fill & bleed or is something wrong? |
Eric_Shea |
May 13 2008, 10:57 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE they slowly expand to their current position Sounds like your knock-back mechanism is hanging on that piston. It may free up when lubricated with the fluid. |
Wanna9146 |
May 13 2008, 11:43 PM
QUOTE they slowly expand to their current position Sounds like your knock-back mechanism is hanging on that piston. It may free up when lubricated with the fluid. I knew you were going to chime in...you're going to make me take everything apart again, right? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/biggrin.gif) You say it "may" free up, but I would rather disassemble now while it's still clean. Is there a way to free-up the knock-back mechanism once I have everything apart? |
Lo-Fi Version | Time is now: 8th June 2024 - 07:31 PM |
