> Running On 5 Cylinders!, AAARRRGGG...
Allan
post May 13 2008, 10:00 PM
Teenerless Weenie
I need some diagnostic help.
Car started missing at low rpm's only.
I thought that it could be a clogged idle jet or poor connection on one of my plug wires (it fits kinda loose).
Pulled all the idle jets and cleaned them up. Crimped the plug connection so it fits better.
No luck. Now it's even worse. Not a miss anymore but what feels like a dead cylinder at low rpm's.
It seems to clear up at higher rpm's but the motor just doesn't seem to pull as strong.
Ideas please... (IMG:style_emoticons/default/smile.gif)
Allan
post May 15 2008, 07:10 PM
Teenerless Weenie
QUOTE(messix @ May 14 2008, 09:21 PM) *
You thought I was kidding? (IMG:style_emoticons/default/huh.gif)
Headrage   Running On 5 Cylinders!   May 13 2008, 10:00 PM
Dr Evil   Compression test :(   May 13 2008, 10:11 PM
Headrage   Compression test :( Wouldn't it be better t...   May 13 2008, 10:14 PM
Dr Evil   Well, I would have figured you tried that first :p...   May 13 2008, 10:19 PM
Joe Mama   AFTER you find the one not working, test the wire ...   May 13 2008, 10:22 PM
Headrage   Not yet. Just took the daughter out for ice cre...   May 13 2008, 10:24 PM
J P Stein   Heh....I can locate the missing cylinder, pull the...   May 13 2008, 10:24 PM
Joe Mama   So????   May 14 2008, 09:47 PM
Headrage   So???? Looks like it's gonna be tomorrow at...   May 14 2008, 10:11 PM
Joe Mama   Prolly next to yer "Man Card".... :Qarl:   May 14 2008, 10:13 PM
messix   "high-voltage gloves " :rotfl: :rotfl:...   May 14 2008, 10:21 PM
Smitty911   What's the problem you have one more cylinder ...   May 14 2008, 11:15 PM
Spoke   On my 4 cylinder engine, I found the non-firing cy...   May 14 2008, 11:20 PM
sww914   Even though you've cleaned all of the idle jet...   May 14 2008, 11:36 PM
Gint   :agree: BTDT myself. Little flaky crap that kept...   May 15 2008, 06:59 AM
Headrage   "high-voltage gloves " :rotfl: :rotfl...   May 15 2008, 07:10 PM
Joe Mama   "high-voltage gloves " :rotfl: :rotf...   May 15 2008, 08:45 PM
Headrage   Anyway, I have narrowed it down to the #2 cylinder...   May 15 2008, 07:12 PM
SGB   Magnacores drove me crazy. They would not secure ...   May 15 2008, 07:21 PM
Root_Werks   If it smooths out at upper RPM's, it's pro...   May 15 2008, 07:23 PM
Headrage   Well, that was a big waste of time. :angry: Re-c...   May 15 2008, 07:54 PM
Root_Werks   Well, that was a big waste of time. :angry: Re-...   May 15 2008, 08:50 PM
messix   swap jets, swap plug wires, if you have another di...   May 15 2008, 08:38 PM
sww914   Nice gloves.   May 15 2008, 08:50 PM
Headrage   I hooked up my timing light to verify that I'm...   May 15 2008, 08:53 PM
Root_Werks   I hooked up my timing light to verify that I...   May 15 2008, 09:16 PM
Headrage   So how do you un-clog an idle circuit?   May 15 2008, 09:25 PM
craig downs   I don't know where on your carbs it is but on ...   May 16 2008, 12:28 AM
Headrage   I don't know where on your carbs it is but on...   May 16 2008, 07:52 AM
!Wet Spot!   Should be....you'll have to take those gloves ...   May 16 2008, 09:44 AM
Headrage   Okay, here's the problem carb. The arrow indi...   May 16 2008, 10:26 AM
sixnotfour   take the jet out and spray in the hole. Also the b...   May 16 2008, 10:44 AM
Headrage   Yep, pulled the plug and even replaced it. Should...   May 16 2008, 10:47 AM
sixnotfour   If it aint broke dont fix , I think is best here. ...   May 16 2008, 10:50 AM
Headrage   I pulled the idle jet and the plug you mentioned. ...   May 16 2008, 10:58 AM
!Wet Spot!   Just so you feel not alone....from the 356 old pha...   May 16 2008, 11:03 AM
So.Cal.914   I believe it should, I think that is where is suck...   May 16 2008, 11:07 AM
Headrage   Success!!! I guess I must of had some...   May 24 2008, 01:41 PM
rhodyguy   good! if the problem becomes persistant i woul...   May 25 2008, 10:05 AM
ConeDodger   Allan, Have you considered doing a four cylinder ...   May 25 2008, 09:34 PM
Phoenix 914-6GT   Allan, Have you considered doing a four cylinder...   May 26 2008, 12:55 AM
besame mi culo   This should fix it..... :DRUNK:   May 25 2008, 10:13 PM
ClayPerrine   http://www.914world.com/bbs2/uploads/post-5-121177...   May 25 2008, 11:04 PM
Gint   What in the hell is that? Are those SU's?   May 25 2008, 11:20 PM
ClayPerrine   What in the hell is that? Are those SU's? ...   May 26 2008, 12:03 AM
Betty   Only running on 5 cylinders?!?!?!?...   May 26 2008, 12:10 AM
ClayPerrine   Only running on 5 cylinders?!?!?!?...   May 26 2008, 12:12 AM
Phoenix 914-6GT   Only running on 5 cylinders?!?!?!?...   May 26 2008, 12:49 AM
- Lo-Fi Version Time is now: 7th July 2025 - 12:52 AM
