WizPorsche914 |
Member ![]() ![]() Group: Members Posts: 132 Joined: 17-December 07 From: Douglassville PA Member No.: 8,479 Region Association: MidAtlantic Region ![]() |
I have a question. Im going to replace my Master Cylinder soon. What tools will I need to do the job and is it easy.
trapper |
Newbie ![]() Group: Members Posts: 37 Joined: 6-February 03 From: Brighton, MI Member No.: 258 ![]() |
QUOTE(Travis Neff @ May 15 2008, 10:58 PM) *
It's a fairly straightforward job, but it is a real bitch to get the feed lines seated into the new MC. Loosen the reservoir retaining strap and you can slide the feed lines down a couple of inches. Also keep track of which line went where, if you reverse them they don't fit right. I just put a 23mm M/C on my 914-6 this past Saturday and am having problems seating the feed lines. Now I'm wondering if I screwed up and crossed the lines. Does anybody have a picture or know which line goes where. There is a left and right coming through the body under the gas tank. Does the left line (outer) go to the front or rear of the M/C? Also, is it easier to put the black rubber grommets on the lines and them insert into the M/C or try to put the lines into the grommets in the M/C? Any special tools you have used for this? Thanks.[i]java script:emoticon(':(', 'smid_2') (IMG:style_emoticons/default/sad.gif) |
trapper |
It's a fairly straightforward job, but it is a real bitch to get the feed lines seated into the new MC. It's done, now I remember why I didn't want to change one of those again! (IMG:style_emoticons/default/headbang.gif) Now for a (IMG:style_emoticons/default/beer3.gif) |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
QUOTE(Travis Neff @ May 15 2008, 10:58 PM) * It's a fairly straightforward job, but it is a real bitch to get the feed lines seated into the new MC. It's done, now I remember why I didn't want to change one of those again! (IMG:style_emoticons/default/headbang.gif) Now for a (IMG:style_emoticons/default/beer3.gif) Any tips or tricks to share? Did you end up pushing the lines in the grommets or putting the grommets on the lines and then inserting? |
Lo-Fi Version | Time is now: 1st July 2025 - 06:54 AM |
