Yet another carb question? |
JOE M |
May 20 2008, 08:37 AM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I got my rebuild kit a few days ago and installed all the parts. I found that the kits came with the later model pump diaphram so I have to use my old pumps until I get the replacements. After about 30 minutes of tuning , the carbs seem to be working well. I still have some fine tuning. Prior to this I had a friend recheck my timing and valve adjsutmnts. All is well and compression is finally even all around about 110psi (still a little low).
So yesterday I started the car and began making some adjustments to the carbs. I turned the car aff and was checking for leaks and I heard a noise like fluid draining. I watched as gas filled each barrell. I am not sure why but after I stop the engine all the gas in the bowl leaks into the barrells (how is thisn possible??). This is happening on both carbs. Any thoughts?????? Thanks in advance. Forgot to say they are weber idf40 |
jmill |
May 20 2008, 10:25 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Where is the fuel coming out? I can't be sure but, from you explaination, I'd say look at your accelerator pumps. It sounds like your draining down the float bowl through your accelerator pumps. Check to make sure you installed everything correctly. Is there little rubber check valves in your pumps? I don't know the IDF that well.
If this is the problem you'll be much leaner after the fix. Make sure your jetted properly. I've seen fuel puke out of carbs when the float level is set incorrectly or the needle doesn't seat well. This only happens when the fuel pump is running though. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:14 PM |
