| 6freak |
May 20 2008, 10:20 AM
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
One session and they where mush and just keep get`n worse Thought they would cool and get maybe a little back but NO
| Rand |
May 20 2008, 11:16 AM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Brake fade?
| 6freak |
May 20 2008, 12:08 PM
Brake fade? WINNER WINNER you get the award because you figured it out (IMG:style_emoticons/default/smilie_pokal.gif) great minds think alike....once again guys....... thanks for the input |
| race914 |
May 20 2008, 12:24 PM
73 914-4 ![]() ![]() ![]() Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Brake fade? WINNER WINNER you get the award because you figured it out (IMG:style_emoticons/default/smilie_pokal.gif) great minds think alike....once again guys....... thanks for the input Heat buildup can cause alot of problems. * Do you still have the big metal splash guards on? They get hot and hold the heat in your rotors & calipers. like little brake ovens (IMG:style_emoticons/default/devil.gif) Take them off if you haven't already. * Brake coolers? These kits to route air into the center of the vented rotor help alot. ![]() * I use ATE Blue and have no problems but change out annually. I've heard MOTUL is good but have no experience with it. Did you bleed the proportioning valve too? That little gem can give you all sorts of grief if it still has air in it. Pads. with all of the above, I still had fade with 'good pads' until I switched to Pagid Orange.... Let us know what you find and what fixes your problems... I had some brake issues recently and it ended up being a frozen piston in one of the front calipers. Was real exciting first high speed lap on practice day!! |
| 6freak |
May 20 2008, 12:48 PM
Brake fade? WINNER WINNER you get the award because you figured it out (IMG:style_emoticons/default/smilie_pokal.gif) great minds think alike....once again guys....... thanks for the input Heat buildup can cause alot of problems. * Do you still have the big metal splash guards on? They get hot and hold the heat in your rotors & calipers. like little brake ovens (IMG:style_emoticons/default/devil.gif) Take them off if you haven't already. * Brake coolers? These kits to route air into the center of the vented rotor help alot. ![]() * I use ATE Blue and have no problems but change out annually. I've heard MOTUL is good but have no experience with it. Did you bleed the proportioning valve too? That little gem can give you all sorts of grief if it still has air in it. Pads. with all of the above, I still had fade with 'good pads' until I switched to Pagid Orange.... Let us know what you find and what fixes your problems... I had some brake issues recently and it ended up being a frozen piston in one of the front calipers. Was real exciting first high speed lap on practice day!! yes splash guards on but not for long good idea..I did use the blue but just changed to the MOTUL heard it was better?? Pagid orange will be ordered tonite for sure.Do they squeel? , .how can i tell the proportion valve thing if its not bled proper..will the vent kit work with a stock front valance?..Thanks |
6freak can`t even stop 2 P May 20 2008, 10:20 AM
purple :WTF: May 20 2008, 11:03 AM
ericread :agree: :WTF:
However;
A winner in the "B... May 20 2008, 11:05 AM
So.Cal.914
Brake fade?
That's what I think too. May 20 2008, 11:21 AM
race914
[quote name='6freak' post='1034358' date='May 20... May 20 2008, 12:58 PM
6freak
[quote name='6freak' post='1034382' date='May 20 ... May 20 2008, 01:27 PM
6freak
[quote name='6freak' post='1034358' date='May 20 ... May 20 2008, 12:59 PM
race914
[quote name='6freak' post='1034358' date='May 20... May 20 2008, 01:04 PM
So.Cal.914
... May 20 2008, 04:50 PM
purple Oh yeah, now that you say.....
stock brakes rebui... May 20 2008, 11:24 AM
Rand Are you already 5-lug? Some vented rotors, Porterf... May 20 2008, 11:34 AM
6freak
Are you already 5-lug? Some vented rotors, Porter... May 20 2008, 12:54 PM
SLITS
One session and they where mush and just keep get... May 20 2008, 11:37 AM
6freak
One session and they where mush and just keep ge... May 20 2008, 11:57 AM
Vacca Rabite http://i109.photobucket.com/albums/n71/sczmaster33... May 20 2008, 11:42 AM
ericread
http://i109.photobucket.com/albums/n71/sczmaster3... May 20 2008, 11:58 AM
6freak
[quote name='Vacca Rabite' post='1034342' date='M... May 20 2008, 12:13 PM
orange914
http://i109.photobucket.com/albums/n71/sczmaster3... May 20 2008, 08:41 PM
purple Nice pic....
ARent braided lines unsafe for not b... May 20 2008, 12:08 PM
6freak
Nice pic....
ARent braided lines unsafe for not ... May 20 2008, 12:34 PM
Cap'n Krusty
Nice pic....
ARent braided lines unsafe for not... May 20 2008, 01:15 PM
ericread
Pagid orange will be ordered tonite for sure.Do ... May 20 2008, 01:26 PM
naro914 Just to throw this out there....but.... if you... May 20 2008, 01:47 PM
6freak
Just to throw this out there....but.... if you... May 20 2008, 03:47 PM
6freak
[quote name='naro914' post='1034413' date='May 20... May 20 2008, 04:10 PM
naro914 Holy smokes batman I watch that blue and yellow 6 ... May 20 2008, 10:00 PM
Elliot Cannon "SAY WHAT AGAIN!" "I DARE YOU... May 20 2008, 02:13 PM
purple oh man, if you want to have some fun with SLJ, the... May 20 2008, 02:15 PM
sww914 FYI, I've had the same braided flex lines in m... May 20 2008, 03:21 PM
6freak
FYI, I've had the same braided flex lines in ... May 20 2008, 04:28 PM
Dan (Almaden Valley) Your problem is not in your braking system. It is... May 20 2008, 04:36 PM
jhadler Ducting, ducting, ducting...
Fresh good fluid, an... May 20 2008, 04:55 PM
Crazyhippy Dont use the brakes so much...
People used to rac... May 20 2008, 05:07 PM
Phoenix 914-6GT Just get them bled well and we can talk about it o... May 20 2008, 05:53 PM
Eric_Shea Race914, Josh and Dan have nailed it.
If you simp... May 20 2008, 07:12 PM
Dan (Almaden Valley) M calipers and vented SC rotors on the front with ... May 20 2008, 07:17 PM
brant I'm kinda late to the party
spent the last 5 d... May 21 2008, 07:36 AM
naro914 I agree in theory with Brant, especially if your c... May 21 2008, 08:17 AM
6freak
I agree in theory with Brant, especially if your ... May 21 2008, 09:52 AM
6freak
I agree in theory with Brant, especially if your... May 29 2008, 01:22 PM
rhodyguy no mention of speed bleeders. you using them? make... May 21 2008, 09:45 AM
roundboy914 quick 'hi Jack' - where can one purchase t... May 21 2008, 03:05 PM
Eric_Shea I see you've finally stopped to P... now you... May 29 2008, 03:28 PM
brant agreed
bleeding again won't fix your sticking ... May 29 2008, 11:07 PM
6freak
agreed
bleeding again won't fix your sticking... May 30 2008, 09:35 AM
carr914
quick 'hi Jack' - where can one purchase ... May 30 2008, 07:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:48 AM |
