> CHP gives cliff a smog ticket for his teener
Chris Hamilton
post May 17 2008, 12:11 AM
Has a 2.0 with webers. Sounds like some kind of fixit ticket. Do 1971 teeners have to smog? (IMG:style_emoticons/default/WTF.gif) How would a six ever smog since those came with carbs too?
Do we have any california law experts here to explain this?
Brando
post May 20 2008, 12:42 PM
BUY MY SPARE KIDNEY!!!
When he asks to see the engine, you pop the front hood.
"Oh crap... uh..."
Then the rear hood.
"Uh oh... Do i even have one?"
VC§ 2806 says that the officer has to have reasonable cause to suspect the engine is modified, or in the instance that the vehicle is a danger to others to search into the car. If you objected to his search and he found nothing, this would constitute an unreasonable search, yadda yadda.
VC§ 2800 says you have to comply with lawful inspections. If you do not comply because it is unlawful (unlawful search and siezure of things on your person, etc).
I'm guessing this brings to light whether or not you believe the search to be lawful. If you contest it and don't oblige the officer's request, it will more than likely become a pissing match in court where its your lawyer vs. the officer's intended enforcement, what he was looking for, questioning his "probable cause" etc.
How much time and money you wanna spend to set precedence?
ericread
post May 20 2008, 01:43 PM
The Viper Blue 914
QUOTE(Brando @ May 20 2008, 11:42 AM) *
"Oh crap... uh..."
Then the rear hood.
As I mentioned earlier in this thread:
No longer is "Probable Cause" a requirement. It has been supplanted by "Reasonable Cause"
In over simplified terms, probable cause exist[s] where the known facts and circumstances are sufficient to warrant a man of reasonable prudence in the belief that contraband or evidence of a crime will be found, Ornelas v. United States, 517 U.S. 690, 696 (1996); Illinois v. Gates, 462 U.S. 213, 238 (1983).
The requirements to support "Reasonable Cause" are very easy to justify by law enforcement.
ConeDodger
post May 20 2008, 03:34 PM
Apex killer!
QUOTE(ericread @ May 20 2008, 12:43 PM) *
"Oh crap... uh..."
Then the rear hood.
Yep. Look at that whale tail. Reasonable cause. Listen to that engine. Reasonable cause. In the case of my engine, you can see the carbs easily through the engine grill. An officer who knew 914's would have me without opening the engine lid. I have no rain tray.
We have a couple CHP officers in SVR... They both would have known where the engine is located and that it didn't come with carbs.
Chris Hamilton   CHP gives cliff a smog ticket for his teener   May 17 2008, 12:11 AM
Dan (Almaden Valley)   has nothing specifically about the carbs, it is ab...   May 17 2008, 12:38 AM
Chris Hamilton   Got pulled over for having an old car with a crapp...   May 17 2008, 12:44 AM
Dan (Almaden Valley)   if they can not pass a smog test, visual and actua...   May 17 2008, 12:48 AM
!Wet Spot!   I'd like to see the CVC or other code it was w...   May 17 2008, 01:08 AM
ericread   Any bets he asked the driver if he could have a lo...   May 17 2008, 02:36 AM
Gint   If the car blew the slightest bit of visible smoke...   May 17 2008, 07:24 AM
rick 918-S   If the car blew the slightest bit of visible smok...   May 17 2008, 08:11 AM
Chris Hamilton   Is there some way for those of us here that have i...   May 17 2008, 08:12 AM
396   Is there some way for those of us here that have ...   May 17 2008, 08:29 AM
grantsfo   Is there some way for those of us here that have ...   May 18 2008, 02:22 PM
!Wet Spot!   For an excessive smoke violation or visible emissi...   May 17 2008, 08:14 AM
rick 918-S   I'm not from the gold coast, but I would think...   May 17 2008, 08:16 AM
So.Cal.914   How many of you have left your wallet at home and ...   May 17 2008, 09:36 AM
biosurfer1   I know police officer's are supposed to enforc...   May 17 2008, 10:26 AM
Wes V   Time for a diatribe and state some facts about smo...   May 17 2008, 11:12 AM
r_towle   Time for a diatribe and state some facts about sm...   May 17 2008, 11:35 AM
So.Cal.914   Time for a diatribe and state some facts about s...   May 17 2008, 12:17 PM
!Wet Spot!   Back in the day, I got yanked over by some rookie ...   May 17 2008, 10:43 AM
Jeff Bowlsby   All 914/4s have at least some smog equipment. See...   May 17 2008, 11:47 AM
Cap'n Krusty   A slight clarification: The smog rule is that the...   May 17 2008, 12:46 PM
Wes V   You can put a '32 Ford engine in your '72...   May 17 2008, 02:12 PM
Cap'n Krusty   You can put a '32 Ford engine in your '7...   May 17 2008, 03:13 PM
Jeff Bowlsby   Huh? The factory emission label above the relay...   May 17 2008, 03:12 PM
Marty Yeoman   ....It seems hard to believe that the same car wo...   May 17 2008, 03:24 PM
!Wet Spot!   ....It seems hard to believe that the same car w...   May 17 2008, 05:09 PM
SirAndy   A slight clarification: The smog rule is that th...   May 17 2008, 03:17 PM
drew365   a lot of us are gambling that no one will ever p...   May 18 2008, 11:00 AM
orange914   A slight clarification: The smog rule is that th...   May 18 2008, 11:45 PM
!Wet Spot!   Unless you can get it dismissed by the guys Superv...   May 17 2008, 12:52 PM
Elliot Cannon   I know someone (a close friend) who has a 1973 914...   May 17 2008, 01:33 PM
Cap'n Krusty   In general, the CHP has nothing to do with smog en...   May 17 2008, 01:57 PM
sww914   The ricers have been dealing with this stuff for y...   May 17 2008, 02:20 PM
Wes V   Another thing the cops like ticketing on the Honda...   May 17 2008, 02:29 PM
Brando   Reading through most of the situation here, this i...   May 17 2008, 05:33 PM
Jeff Bowlsby   ...a stock 1974 (1974 model year car, 1975 ship/l...   May 17 2008, 09:27 PM
Dan (Almaden Valley)   OK, so the answer to the question is this. I was p...   May 17 2008, 06:43 PM
Chris Hamilton   OK, so the answer to the question is this. I was ...   May 17 2008, 07:08 PM
brer   should have said it was a diesel. :D   May 17 2008, 07:01 PM
Dan (Almaden Valley)   like stated above. just because it doesn't ha...   May 17 2008, 08:08 PM
ConeDodger   I would bet the next step in the process for this ...   May 17 2008, 08:23 PM
!Wet Spot!   A smoke ticket is NOT a reasonable cause for a smo...   May 17 2008, 09:12 PM
brer   this is what you say. I'm sorry officer but ...   May 17 2008, 10:04 PM
computers4kids   this is what you say. I'm sorry officer but...   May 18 2008, 12:10 AM
Cap'n Krusty   To stop the speculation, you might want to tell us...   May 17 2008, 10:45 PM
!Wet Spot!   To stop the speculation, you might want to tell u...   May 17 2008, 11:13 PM
rick 918-S   To stop the speculation, you might want to tell ...   May 17 2008, 11:31 PM
Chris Hamilton   I'll find out as soon as he gets home. Thanks.   May 17 2008, 11:06 PM
Wanna9146   So what happens to a 914/8 conversion in a similar...   May 17 2008, 11:34 PM
Chris Hamilton   So what happens to a 914/8 conversion in a simila...   May 18 2008, 02:11 AM
shoguneagle   A V-8 conversion can be made legal if you follow t...   May 18 2008, 04:38 AM
!Wet Spot!   Interesting to see if the BAR would actually inspe...   May 18 2008, 08:31 AM
Chris Hamilton   Grant, the V8 doesn't have any parts that came...   May 18 2008, 08:48 PM
CliffBraun   Just wanted to pop my head in and say hi, nothing ...   May 18 2008, 09:24 PM
JimSar   I've got a '75 that's all electric; no...   May 19 2008, 12:40 AM
swl   Jim, I've been thinking about that through the...   May 19 2008, 07:02 AM
ClayPerrine   This :stromberg: is why I am HAPPY that I don...   May 19 2008, 08:22 AM
rick 918-S   I just gave that link a good speed read and it app...   May 19 2008, 08:57 AM
Dan (Almaden Valley)   I just gave that link a good speed read and it ap...   May 19 2008, 11:09 AM
ericread   the state doesn't care if the stuff is NLA or...   May 19 2008, 11:23 AM
Cap'n Krusty   I just gave that link a good speed read and it a...   May 20 2008, 01:19 AM
Chris Hamilton   Grant, lets see that video!   May 19 2008, 10:59 AM
Wes V   I think this string got way off topic (but covered...   May 19 2008, 11:29 AM
grantsfo   Grant, lets see that video! Sorry its not th...   May 19 2008, 11:28 PM
Chris Hamilton   Grant, lets see that video! Sorry its not t...   May 19 2008, 11:41 PM
Dan (Almaden Valley)   what has or hasn't been changed on his car is ...   May 19 2008, 12:15 PM
SirAndy   the car also has a HUGE whale tale on it, lots of...   May 19 2008, 01:00 PM
Chris Hamilton   [quote name='Dan (Almaden Valley)' post='...   May 19 2008, 01:28 PM
ericread   [quote name='Dan (Almaden Valley)' post=...   May 19 2008, 01:39 PM
!Wet Spot!   An electric car when re-registered after conversio...   May 19 2008, 12:35 PM
Chris Hamilton   The ticket says he was written up under VC 27156, ...   May 19 2008, 12:42 PM
Dan (Almaden Valley)   exactly Chris....   May 19 2008, 12:51 PM
SLITS   27156. (a) No person shall operate or leave stand...   May 19 2008, 01:11 PM
!Wet Spot!   Plenty of exemptions to that standard.....I have a...   May 19 2008, 01:19 PM
!Wet Spot!   Or "free donuts".....   May 19 2008, 01:41 PM
Wes V   Now why would the cop think the engine may be modi...   May 19 2008, 01:55 PM
rick 918-S   Can anyone tell me what "polution control dev...   May 19 2008, 02:28 PM
Jeff Bowlsby   All 914s at least had the charcoal filter and pipi...   May 19 2008, 02:36 PM
Dan (Almaden Valley)   his car certainly didn't come stock with dual ...   May 19 2008, 02:47 PM
CliffBraun   Okay, here's an update for everyone, I've ...   May 19 2008, 02:50 PM
SirAndy   a used 1.7L with all injection parts can be had fo...   May 19 2008, 03:15 PM
CliffBraun   Blah. Went to the referee station, sans car, to s...   May 19 2008, 07:58 PM
dw914er   technically, i am in the crack of the smog law. I ...   May 20 2008, 12:13 AM
Cap'n Krusty   technically, i am in the crack of the smog law. I...   May 20 2008, 01:28 AM
dw914er   technically, i am in the crack of the smog law. ...   May 20 2008, 01:47 AM
Dan (Almaden Valley)   even the california cars had to be tweeked to pass...   May 20 2008, 12:21 AM
Cap'n Krusty   The statement about the exemption is only partiall...   May 20 2008, 01:26 AM
joefri187   There was a lot of discussion earler regarding the...   May 20 2008, 02:02 AM
ericread   There was a lot of discussion earler regarding th...   May 20 2008, 09:09 AM
ConeDodger   There was a lot of discussion earler regarding t...   May 20 2008, 10:54 AM
Brando   When he asks to see the engine, you pop the front ...   May 20 2008, 12:42 PM
ericread   When he asks to see the engine, you pop the front...   May 20 2008, 01:43 PM
ConeDodger   [quote name='Brando' post='1034377' date='May 20 ...   May 20 2008, 03:34 PM
dw914er   it is pretty amazing though that the officer knew ...   May 20 2008, 01:30 PM
Chris Hamilton   it is pretty amazing though that the officer knew...   May 20 2008, 01:33 PM
dw914er   it is pretty amazing though that the officer kne...   May 20 2008, 01:42 PM
ericread   HA! No rain tray!!! You lawless ...   May 20 2008, 03:38 PM
rjames   A drive by emissions test? Pardon my ignorance,...   May 20 2008, 04:06 PM
Cap'n Krusty   A drive by emissions test? Pardon my ignorance...   May 20 2008, 04:11 PM
dw914er   those tests usually wont test the 914 unless you a...   May 20 2008, 04:16 PM
- Lo-Fi Version Time is now: 19th December 2025 - 06:51 AM
