> AX transmission
r_towle
post Mar 15 2003, 05:24 PM
Custom Member
So,
I want to stop shifting so much at the Autocross.
What gears would you all recommend???
Rich
Zeke
post Mar 21 2003, 05:53 PM
Never left, but not right....
QUOTE(r_towle @ Mar 21 2003, 03:33 PM)
I am close to understanding this...please forgive my ignorance here, I have only done motors, never doen a tranny.
So I have three side shifters, and a tail shifter.
I am going to do this to a "spare" side shifter...
When I get going, I will take a pic of two and ask my dumb questions.
Brad, I am flipping the fifth Drive gear with the Third Drive gear???
Or the fifth drive with the third driven...
Or aaaarrrrggggg...
Rich (IMG:style_emoticons/default/pray.gif)
Rich, I just did this, so it's fresh on my mind. What you are doing is swapping both complete sets for each other. I don't know about the 3rd to 5th swap, that might be too low for the street. But the 5th to 3rd drops 3rd down closer to 2nd. With that, you would be better off dropping 4th down a liitle too, IMHO.
The 5th is on one cluster and 3rd is on another cluster. Except for the gear sizes, these clusters look/work the same. When you install the gear from 5th into the 2nd-3rd cluster, it's in the same position realtive to the cluster as it was before. Except, it's upside down, hence the reverse diagonal cut.
Hope that's clear as trans fluid. None of this makes much sense unless you are racing the car. (IMG:style_emoticons/default/driving.gif)
r_towle   AX transmission   Mar 15 2003, 05:24 PM
ChrisReale   Not a professional answer (ill leave that to the "...   Mar 15 2003, 06:15 PM
Zeke   In that case, Chris, I think you're friend has...   Mar 15 2003, 06:42 PM
J P Stein   I would like an A or B first. We are pretty much S...   Mar 15 2003, 07:57 PM
ChrisReale   Zeke, he IS going faster than me, by about ten f...   Mar 15 2003, 08:50 PM
J P Stein   <...   Mar 19 2003, 08:33 PM
porsche735   Rich, As I said, no gears to buy. All you do is m...   Mar 19 2003, 09:24 PM
Brad Roberts   I normally use the terms (Drive and Driven gears) ...   Mar 19 2003, 09:35 PM
Brad Roberts   Richard, We flip 5th gear to make a new shorter 3...   Mar 19 2003, 10:52 PM
Mike T
  Mar 20 2003, 08:19 AM
drew365   This sounds like a good mod for a short road cours...   Mar 20 2003, 09:46 AM
Joseph Mills   I've been given two spare trannys from an ex-r...   Mar 20 2003, 10:18 AM
Brad Roberts   Joseph. Flip a 5th from the tranny you want to us...   Mar 20 2003, 11:08 AM
Brad Roberts   Oh, we chat about this like it is nothing. NONE o...   Mar 20 2003, 11:10 AM
James Adams   Gear chart for about a stock diameter tire (calcul...   Mar 20 2003, 11:19 AM
Zeke
  Mar 20 2003, 12:51 PM
Travis Neff   So, for a hot street setup - you would want to obt...   Mar 20 2003, 01:19 PM
TimT   Brad I took the liberty to play with the pic yo...   Mar 20 2003, 03:58 PM
TimT   oops helps to attach the pic   Mar 20 2003, 04:03 PM
Zeke   I just did this and that's exactly what it loo...   Mar 20 2003, 04:31 PM
bpick84   It will run okay in reverse cut, but it may whine ...   Mar 21 2003, 09:35 AM
Zeke   No one is gonna explain to me what "delta" is (I t...   Mar 21 2003, 10:46 AM
Mueller   3.09-1.89=1.2 1.2/3.09=39% differance (delta) 1.8...   Mar 21 2003, 11:13 AM
Demick   I think the picture in Tim's post above shows ...   Mar 21 2003, 12:04 PM
Brad Roberts   Bill Pickering ?? If that is you... welcome. Thank...   Mar 21 2003, 12:17 PM
r_towle   I am close to understanding this...please forgive ...   Mar 21 2003, 05:33 PM
TimT
  Mar 21 2003, 05:38 PM
Zeke   <...   Mar 21 2003, 05:53 PM
Demick   Rich Drive gears are always on the input shaft, d...   Mar 21 2003, 06:05 PM
Brad Roberts   It wasnt designed for it, but I personally have be...   Mar 21 2003, 06:22 PM
TimT   I wondered about the thrust issue. Then being an e...   Mar 21 2003, 06:38 PM
porsche735   Back to this stock 5th thing.... Why would you wa...   Mar 21 2003, 07:08 PM
TimT   Milt did you get that spreadsheet I sent your way...   Mar 21 2003, 07:24 PM
Racer Chris     Mar 21 2003, 11:17 PM
Brad Roberts   Chris, The thread started out as a AUTOX thread.....   Mar 21 2003, 11:49 PM
TimT   Chris, I just bought the GT4 car, havent turned a ...   Mar 22 2003, 08:31 AM
Racer Chris     Mar 22 2003, 05:29 PM
TimT   Chris I know your were teasing just wanted to use ...   Mar 22 2003, 06:28 PM
mskala   This may not apply to many, but for PCA AX in our ...   Mar 22 2003, 06:57 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:26 AM
