> NEWBIE WITH Q's, getting a 914 and need some help
bangingears
post May 23 2008, 02:27 AM
Hello, My names Adam, for years I have wanted a 914 and, low and behold I believe this is the year ill be getting one! I know I want a street legal go cart, I have several years of experience building type 1 motors, and this is why i chose this car (similarity...however more ?'s on that later)..... i figure for suspension I am going to do the following
Front sway bar
Koni sport shocks with rubber bump stops
Rebel racing rear coil overs
Tangerine racing chassis stiffin kit
and build a full cage for Chassis Rigidity.
here is where I feel alittle out of the loop.... i did alot of research and from 3 different machine shops, recieved three different answers.... one... said all 1.7 1.8 and 2.0 cases are the SAME...and interchange parts (i know they are wrong... the bore size on each case is different) second said, the cases are the same, however the 1.7 and 1.8 ONLY need cylinder bore inlarged... and the third said all 3 cases where different. So wats the real answer????
And FInally.... where do you guys go for performance parts? I.E, counterweight cranks, rods, pistons, valves? Porting? ... whats the best performance shop to go to?
Please if you can help at all please share your opinion.
thank you!
bangingears
post May 23 2008, 03:44 PM
thanks guys.. i am stoked on this project! i have build several 160hp t1's in the same size range 1900cc-2110, i figure a 2056 will provide me with enough power.
bangingears
post May 24 2008, 02:07 PM
what size webers are all you guys running? ik now i use to run 48 IDA's on agressive camed bugs... what do you guys recommend
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 PM
