> Torsion bars-what size to get?, Damn, I have to fix someting else!
marks914
post May 26 2008, 04:31 PM
Just got home from a little vacation with the family, went to pull the teener out to take to the store and noticed that the pass side front was extremely low to the ground. Checked the height adjuster and it it loose, I can move it by hand, so I can only assume that the torsion bar has snapped. Good thing it happened in my garage I guess. Seems kind of wierd that it would just go like that.
Anyhow, what size bars should I get? Its a SBC car with 200# springs in back, mostly a street car with an occasional trip to the track. I have a 19 mm sway bar in the front as
well. I liked the way it rode/handled with the stock bars.
It has the stock 914 suspension with 911 struts.
Any sources?
Any tips for the removal/intstallation?
Will any 911 bars go right back in there?
Thanks
Mark
marks914
post May 26 2008, 10:11 PM
What bushings do I need to get? All I can see on the diagram are the control arm bushings and the t-bar seal
Mark
marks914   Torsion bars-what size to get?   May 26 2008, 04:31 PM
Todd Enlund   It has the stock 914 suspension with 911 struts. ...   May 26 2008, 05:01 PM
SirAndy   911 and 914 torsion bars are not interchangeable....   May 26 2008, 06:58 PM
Eric_Shea   What they said. Stock would be my choice.   May 26 2008, 08:46 PM
marks914   Thanks, Seems kind of strange that one side would ...   May 26 2008, 09:02 PM
ConeDodger   You aren't complaining about the handling so I...   May 26 2008, 09:09 PM
Eric_Shea   Happens a lot actually. This is an indicator to...   May 26 2008, 09:27 PM
justme   Just got home from a little vacation with the fam...   May 26 2008, 09:46 PM
marks914   What bushings do I need to get? All I can see on ...   May 26 2008, 10:11 PM
craig downs   There are a couple of choices. You can go with McM...   May 26 2008, 10:33 PM
Phoenix 914-6GT   I like my 23mm hollows :D I have the delrin bushi...   May 27 2008, 01:26 AM
Travis Neff   You can go up a little in size by getting 911 A-Ar...   May 27 2008, 12:07 PM
Phoenix 914-6GT   You can go up a little in size by getting 911 A-A...   May 27 2008, 12:38 PM
andys   What are the available stock 911 torsion bars size...   May 27 2008, 01:04 PM
Travis Neff   18.8 for the 911 fronts, which is 1mm larger than ...   May 27 2008, 01:18 PM
Eric_Shea   His larger rears are compensating for the weight o...   May 27 2008, 06:25 PM
ConeDodger   His larger rears are compensating for the weight ...   May 27 2008, 06:35 PM
rhodyguy   do you like the way it drives and handles now (pri...   May 28 2008, 12:24 AM
marks914   Thanks everybody, I think I will keep it stock, it...   May 28 2008, 06:01 AM
Wannabe 914-6 owner   I really like the look of your car, especially the...   May 28 2008, 10:01 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:35 PM
