| marks914 |
May 26 2008, 04:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Just got home from a little vacation with the family, went to pull the teener out to take to the store and noticed that the pass side front was extremely low to the ground. Checked the height adjuster and it it loose, I can move it by hand, so I can only assume that the torsion bar has snapped. Good thing it happened in my garage I guess. Seems kind of wierd that it would just go like that.
Anyhow, what size bars should I get? Its a SBC car with 200# springs in back, mostly a street car with an occasional trip to the track. I have a 19 mm sway bar in the front as well. I liked the way it rode/handled with the stock bars. It has the stock 914 suspension with 911 struts. Any sources? Any tips for the removal/intstallation? Will any 911 bars go right back in there? Thanks Mark Attached image(s)
| Eric_Shea |
May 27 2008, 06:25 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
His larger rears are compensating for the weight of a V8.
If you were happy with stock before... there's a free set a couple posts up. Hard to beat. I'm not a fan of big bars for street cars. I would say the 911 19mm's (18.8's) would be tops but again, you're going to have to get all new a-arms from a 911 to fit them. This is now "way" out of the plug-and-play arena. Bigger is not always better. (IMG:style_emoticons/default/wink.gif) |
marks914 Torsion bars-what size to get? May 26 2008, 04:31 PM
Todd Enlund
... May 26 2008, 05:01 PM
911 and 914 torsion bars are not interchangeable.... May 26 2008, 06:58 PM
Eric_Shea What they said.
Stock would be my choice. May 26 2008, 08:46 PM
marks914 Thanks,
Seems kind of strange that one side would ... May 26 2008, 09:02 PM
ConeDodger You aren't complaining about the handling so I... May 26 2008, 09:09 PM
Eric_Shea
Happens a lot actually.
This is an indicator to... May 26 2008, 09:27 PM
justme
Just got home from a little vacation with the fam... May 26 2008, 09:46 PM
marks914 What bushings do I need to get? All I can see on ... May 26 2008, 10:11 PM
craig downs There are a couple of choices. You can go with McM... May 26 2008, 10:33 PM
Phoenix 914-6GT I like my 23mm hollows :D I have the delrin bushi... May 27 2008, 01:26 AM
Travis Neff You can go up a little in size by getting 911 A-Ar... May 27 2008, 12:07 PM
Phoenix 914-6GT
You can go up a little in size by getting 911 A-A... May 27 2008, 12:38 PM
andys What are the available stock 911 torsion bars size... May 27 2008, 01:04 PM
Travis Neff 18.8 for the 911 fronts, which is 1mm larger than ... May 27 2008, 01:18 PM
ConeDodger
His larger rears are compensating for the weight ... May 27 2008, 06:35 PM
rhodyguy do you like the way it drives and handles now (pri... May 28 2008, 12:24 AM
marks914 Thanks everybody, I think I will keep it stock, it... May 28 2008, 06:01 AM
Wannabe 914-6 owner I really like the look of your car, especially the... May 28 2008, 10:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:49 PM |
