| mattp |
Jun 1 2008, 09:23 PM
Member ![]() ![]() Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
installing new engine with carbs, had a 1.8, I need some ideas on where/ how you may have mounted (anchored) your throttle cable, thanks
| VaccaRabite |
Jun 2 2008, 10:31 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,929 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Found them. This is what I made. Ken (Zymirgist)took these pics on April 12.
(IMG:http://www.914world.com/bbs2/uploads/post-4238-1208061514.jpg) it is a small piece of 1/8 inch steel with 2 holes drilled in it, and bent at an angle. (IMG:http://www.914world.com/bbs2/uploads/post-4238-1208061157.jpg) Here is how it runs to the linkage. Simple and strong. The cable should not have to make any sharp bends to get to the engine from the firewall, unlike some of the other attachments I have seen. The short piece of metal does not allow much (if any) flex, and should not provide as much mechanical advantage against the case (causing the case to break). Zach |
mattp need some pics of carb linkage Jun 1 2008, 09:23 PM
96740 :popcorn: Jun 1 2008, 09:32 PM
Phoenix 914-6GT :Qarl: Jun 1 2008, 09:51 PM
96740
:Qarl:
What is that bent box wrench looking thi... Jun 1 2008, 10:24 PM
Phoenix 914-6GT http://www.triadwestperformance.com/Products.htm Jun 1 2008, 11:03 PM
96740
... Jun 1 2008, 11:05 PM
Phoenix 914-6GT
[quote name='Phoenix 914-6GT' post='1039608'... Jun 1 2008, 11:24 PM
rhodyguy that cable bracket is incuded in the Triad linkage... Jun 1 2008, 11:07 PM
96740 Thanks for the link. Jun 2 2008, 08:54 AM
URY914 It's the best set up out there. Jun 2 2008, 08:59 AM
mattp I have the linkage set up from Raby, that box wren... Jun 2 2008, 09:45 AM
Vacca Rabite I rigged up a very simple (and strong) system. I ... Jun 2 2008, 10:17 AM
96740
Found them. This is what I made. Ken (Zymirgist... Jun 4 2008, 12:19 AM
Gint The CB Performance linkage set works just fine for... Jun 2 2008, 12:06 PM
dbgriffith75 Wow I wish I had a mean looking linkage like those... Jun 2 2008, 01:05 PM
mattp how do you attach the linkage to the carbs?
Also ... Jun 3 2008, 10:10 PM
rhodyguy use the hole in the pass side engine tin that is p... Jun 4 2008, 09:32 AM
Kargeek CB Linkage- Homemade bracket made with a hacksaw. ... Jun 4 2008, 10:56 AM
96740
CB Linkage- Homemade bracket made with a hacksaw.... Jun 4 2008, 08:47 PM
anderssj CB linkage with home-made throttle bracket--always... Jun 4 2008, 08:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 12:57 AM |
