My Car Won't start?, Battery cranks it over, but engine will not run |
levonfarra |
Jun 2 2008, 12:17 PM
Member Group: Members Posts: 173 Joined: 10-February 07 From: Encino, CA Member No.: 7,521 Region Association: None |
Hello,
My engine will not run as topic states. I usually hear the fuel pump humming when I first turn on the ignition. But now I do not hear that noise, has my fuel pump gone bad, or can it be something else that can cause that and disable my car from running. Any ideas, comments or suggestions? Thanks, Levon |
yellow914 |
Jun 2 2008, 01:05 PM
Member Group: Members Posts: 183 Joined: 28-March 08 From: San Jose, CA Member No.: 8,861 Region Association: Northern California |
Could be that pesky ignition switch again!..mine played this same scenario out until I noticed that my gas gauge didn't move when I turned the key...then I'd try again and again and again almost running the battery out...then I'd notice the gauge jump on and viola started right off the bat!....I though it I let it sit it would start and many times it did...I think the plastic switch was just shrinking back together after my many many attempts to start and making a connection...Watch your guages and if they don't react it won't start?
Lo-Fi Version | Time is now: 10th June 2024 - 10:42 PM |
