where to get ebrake cable extensions? |
rfuerst911sc |
Jun 1 2008, 02:16 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have converted my 914 to 5 lug and 911 ebrake. I cutoff the OEM ebrake mounting tabs on the swing arm and welded them back on but straight back. Now that that is done I need cable extensions aprox. 6-7 inches long. Ideally these extensions would have eyelets on both ends. Where do you go to have something like this made? This is just a cable with no sheathing, I welded a bolt onto the bottom of each swing arm and mounted a bearing wheel. I'm expecting the cable extension to ride in this wheel. Any ideas?
rfuerst911sc |
Jun 2 2008, 05:47 PM
My setup is different from others as I didn't plan on useing a bellcrank to activate the 911 ebrake. My plan was/is to extend the OEM 914 cables with aircraft cable with no sheathing to wrap around the roller bearing pulleys in the pic. Any suggestions are appreciated. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 12th June 2024 - 01:57 AM |
