Transmission numbers.., Where's the chart, or what do they mean? |
RJMII |
Jun 2 2008, 02:19 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
on the bottom middle rib of the transmission;
CA081 3801 (can I use gears out of it? What gears are likely to be in it?) HA 1010 5 (What gears are likely to be in it? or where is the chart? HA 130 03 3 (What gears are likely to be in it? or where is the chart?) I've tried finding the chart, and I've looked at the chart in Greg's spreadsheet, but am not quite sure how to tell. I'm also not sure of the numbers on the first HA unit, and I'm thinking the CA is a bus transaxle. The HA 1010 5 unit, the numbers looked a bit weird and I couldn't quite read them. If that's not the right figuring of numbers, I can go look again and get a picture. |
davep |
Jun 2 2008, 10:02 PM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
More info since it is hard to find:
914/4 types 914/11 & 914/12: A, F, N, V, ZD with 7/31 crown & pinion 914/6 type 914/01 5 SPEED: A, GA, O/3, V, ZA with 7/31 crown & pinion 914/6 type 914/05 SPORTO: C, I, Q/4, X with 7/27 crown & pinion A=11/34 C=15/36 F=18/34 G=18/32 I=20/31 N=23/29 O3=23/28 Q4=24/27 V=27/25 X=28/24 ZA=29/22 ZD=31/22 |
Lo-Fi Version | Time is now: 12th June 2024 - 01:25 AM |
