CV joint washer- which way? |
dbgriffith75 |
May 27 2008, 02:12 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
I'm sure pics would be of help here, but I don't have much time before I have to get off to work, so if you can advise me on this w/out them, great. If not, I'll try to get some posted tomorrow.
On the CV axle/joint assembly, there's a cupped washer (can't think of a better way to describe it) that fits behind the joint assembly, against a flare on the axle at the end of the splines. What I'd like to know is which way is that washer supposed to be positioned- with the cup towards the joint assembly, or away from it? Mechanically speaking, I think it should be positioned toward the assembly to keep tension on the snap ring, but I'd like a second/third/fourth/25th opinion. (IMG:style_emoticons/default/biggrin.gif) Thanks! I'll check back tomorrow. |
dbgriffith75 |
Jun 4 2008, 10:56 AM
Back on the CV joints, I got my new snap rings, now I'm just curious what the best way to go about installing them is. The joint inner race needs to be pressed down some to allow the ring to seat into the groove on the shaft.
One thing I've already tried is a furniture clamp on the inner race, the other end on the axle, but that didn't work. And I don't want to start beating the piss out of it trying to get the ring to seat. Any suggestions? |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:30 PM |
