| Justinp71 |
Jun 4 2008, 11:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
Well it seems that a good way to make sure your car is using the proper amount of fuel is to add a Air/Fuel meter, especially since few of these cars have modern computers. So I am looking at what options are available.
It looks like one option is to buy a kit from pelican: http://www.pelicanparts.com/cgi-bin/ksearc...r=PEL-SW85-2437 Option 2: Use an 80-83 911 o2 sensor and add an aftermarket gauge...(Which I guess is similiar). I would like to use this sensor, b/c there is a chance I may use an 81 CIS system later on. So... does anyone have any recomendations and/or suggestions? |
| Gint |
Jun 5 2008, 08:39 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
We've been running an LC-1, with an XD-16 for about 3 years constant now we leave it in and turned on for every single run, every single day our tracks vary in altitude from 5,000 to 900 foot and we rejet for each different one. it's interesting data actually and can pick up on things you would otherwise miss 3 weeks ago we went to texas for a 3 day weekend. my Innovate told me something was wrong at full throttle as it started spiking lean intermittently turns out I sucked an intake gasket slightly you couldn't feel it by seat of the pants. but you could see it on the guage. I added the rare and often unused auxillary enrichment circuits to my IDS carbs this year and completely had to re-think my jetting. I could of never done this without the innovate. the car feels absolutely the same but I'm now able to keep my AFR from 12.5 tp 13.5 (1 full point) where I was only able to run from 12.5 to 14.5 (2 points) previously. the LC-1 shows a double curve now that the car gradually leans out from 4,000rpm until about 6,000 rpm and then the auxillaries kick in (vacuum draw) and the car goes towards the heavier/richer mixture and drops from 13 back to 12.5 at 6K.... then gradually leans itself again. You don't feel any of this but you can see it in fact on the first lap out it doesn't follow this pattern and runs lean for 1 lap my theory is that the aux enrichments need to "prime" or build suction and it takes about 2 hard runs to redline before they are primed or full of fuel I can watch the weather change on the guage I run lean in the mornings and rich in the afternoons based on the change in ambient temp. again you don't feel any of this but you can read it on the guage and change your jetting That's a great post. Thanks Brant. |
Justinp71 Air/Fuel Meter and O2 Sensor Jun 4 2008, 11:45 AM
biosurfer1 could try making your own:
http://www.scirocco.or... Jun 4 2008, 11:52 AM
Demick Unless it's wide band, it's basically usel... Jun 4 2008, 12:20 PM
Justinp71 I looked up the info for the K&N A/F meters th... Jun 4 2008, 12:42 PM
ConeDodger Justin,
I am doing the Innovate LM something or o... Jun 4 2008, 12:43 PM
iamchappy I have the LC-1 with the onboard gauge, the innova... Jun 4 2008, 01:28 PM
McMark It's a common misconception that an oxygen sen... Jun 4 2008, 01:49 PM
Marty Yeoman
"on over-run you want a leaner mixture... Jun 4 2008, 02:28 PM
orange914
Please explain "over-run"? :worship:
... Jun 4 2008, 07:11 PM
Brando "on over-run you want a leaner mixture"g... Jun 5 2008, 12:45 PM
orange914
[quote name='orange914' post='1040822' date='Jun ... Jun 5 2008, 02:18 PM
Gint Over-run is when you left off of the gas... Jun 4 2008, 02:37 PM
toon1 There is a a company called" JAW", out i... Jun 4 2008, 02:43 PM
Joe Owensby I saw 2 different ones that look reasonably afford... Jun 4 2008, 05:30 PM
toon1
I saw 2 different ones that look reasonably affor... Jun 4 2008, 05:53 PM
Borderline I have the Innovate LC-1 and have mixed emotions. ... Jun 4 2008, 06:24 PM
jesiv I have been looking at doing this as well. You mi... Jun 4 2008, 07:25 PM
roadster fan
I have been looking at doing this as well. You m... Jun 5 2008, 03:24 AM
jesiv
[quote name='jesiv' post='1040827' date='Jun 4 20... Jun 5 2008, 08:39 AM
TimT
Werd....
We have a few of these in the shop tha... Jun 4 2008, 07:28 PM
LvSteveH I really like the LM1. It has a data recorder that... Jun 4 2008, 08:38 PM
brant We've been running an LC-1, with an XD-16 for ... Jun 5 2008, 12:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:34 AM |
