| Justinp71 |
Jun 4 2008, 11:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
Well it seems that a good way to make sure your car is using the proper amount of fuel is to add a Air/Fuel meter, especially since few of these cars have modern computers. So I am looking at what options are available.
It looks like one option is to buy a kit from pelican: http://www.pelicanparts.com/cgi-bin/ksearc...r=PEL-SW85-2437 Option 2: Use an 80-83 911 o2 sensor and add an aftermarket gauge...(Which I guess is similiar). I would like to use this sensor, b/c there is a chance I may use an 81 CIS system later on. So... does anyone have any recomendations and/or suggestions? |
| MartyYeoman |
Jun 4 2008, 02:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,546 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California
"on over-run you want a leaner mixture" Please explain "over-run"? (IMG:style_emoticons/default/pray.gif) |
| orange914 |
Jun 4 2008, 07:11 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
"on over-run you want a leaner mixture" get a 1975 or 76 2.0 ecu it has the lean out decel for both emmisions and m.p.g. ![]() |
| Brando |
Jun 5 2008, 12:45 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
"on over-run you want a leaner mixture" get a 1975 or 76 2.0 ecu it has the lean out decel for both emmisions and m.p.g.I think that was 76 only, I have a 75 and it doesn't cut fuel on deceleration. (IMG:style_emoticons/default/sad.gif) |
| orange914 |
Jun 5 2008, 02:18 PM
"on over-run you want a leaner mixture" get a 1975 or 76 2.0 ecu it has the lean out decel for both emmisions and m.p.g.I think that was 76 only, I have a 75 and it doesn't cut fuel on deceleration. (IMG:style_emoticons/default/sad.gif) the 75 must have a different # than 76 then. do you know which mine is? could some have the feature and some may not (calif./48 state)? how did you find yours doesn't? |
Justinp71 Air/Fuel Meter and O2 Sensor Jun 4 2008, 11:45 AM
biosurfer1 could try making your own:
http://www.scirocco.or... Jun 4 2008, 11:52 AM
Demick Unless it's wide band, it's basically usel... Jun 4 2008, 12:20 PM
Justinp71 I looked up the info for the K&N A/F meters th... Jun 4 2008, 12:42 PM
ConeDodger Justin,
I am doing the Innovate LM something or o... Jun 4 2008, 12:43 PM
iamchappy I have the LC-1 with the onboard gauge, the innova... Jun 4 2008, 01:28 PM
McMark It's a common misconception that an oxygen sen... Jun 4 2008, 01:49 PM
Gint Over-run is when you left off of the gas... Jun 4 2008, 02:37 PM
toon1 There is a a company called" JAW", out i... Jun 4 2008, 02:43 PM
Joe Owensby I saw 2 different ones that look reasonably afford... Jun 4 2008, 05:30 PM
toon1
I saw 2 different ones that look reasonably affor... Jun 4 2008, 05:53 PM
Borderline I have the Innovate LC-1 and have mixed emotions. ... Jun 4 2008, 06:24 PM
jesiv I have been looking at doing this as well. You mi... Jun 4 2008, 07:25 PM
roadster fan
I have been looking at doing this as well. You m... Jun 5 2008, 03:24 AM
jesiv
[quote name='jesiv' post='1040827' date='Jun 4 20... Jun 5 2008, 08:39 AM
TimT
Werd....
We have a few of these in the shop tha... Jun 4 2008, 07:28 PM
LvSteveH I really like the LM1. It has a data recorder that... Jun 4 2008, 08:38 PM
brant We've been running an LC-1, with an XD-16 for ... Jun 5 2008, 12:24 AM
Gint
We've been running an LC-1, with an XD-16 for... Jun 5 2008, 08:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
