914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I finally got my repro VIN stickers for my cars. They look pretty good. They are not punched but digital reproduced. They are in the correct silver color. I think they will pass the muster for me.
Attached image(s) ![]() |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
If you're in California, you might want to check with the CHP before applying any other-than-factory VIN sticker. I know for sure that if you try to rivet on your own window tag, it is a BIG deal. We're talkin FELONY. So, check with your local CHP office befor affixing any stickers. FWIW.
Cheers, Elliot |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
If you're in California, you might want to check with the CHP before applying any other-than-factory VIN sticker. I know for sure that if you try to rivet on your own window tag, it is a BIG deal. We're talkin FELONY. So, check with your local CHP office befor affixing any stickers. FWIW. Cheers, Elliot Technically it's an information sticker. Even the OEM replacement sticker from Porsche isn't an exact match. It would only be illegal if you tried to use a different # or "tamper". Can you imagine trying to prosecute someone that had the correct # on his car and the court trying to prove that a $2.00 decal isn't perfect but the # was correct? As messed up as our judicial system is that won't make it...... |
Lo-Fi Version | Time is now: 4th July 2025 - 12:55 PM |
