Morphenspectra Subwoofer Box, Passenger Footwell Type |
Allan |
Jun 3 2008, 11:10 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I just got my new subwoofer enclosure from James, but have a question.
Who has one, and how did you secure it in the footwell? Btw, I highly recommend it if you're wanting bigger sounds in the car... (IMG:style_emoticons/default/smile.gif) |
RoadGlue |
Jun 11 2008, 01:21 AM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
The 8W1v2-4 looks like it's a perfect match for the box, though it's not part of the W3 series that you're looking for:
http://www.crutchfield.com/App/Product/Ite...ofer&tp=111 # 8" 4-ohm subwoofer # metallic-finish polypropylene cone with nitrile-butylene rubber surround # power range: 35-150 watts RMS # peak power handling: 300 watts # frequency response: 28-250 Hz # sensitivity: 83.86 dB # top-mount depth: 3-13/16" # sealed box volume: 0.375 cubic feet |
GringoLoco |
Jun 11 2008, 01:36 AM
Member Group: Members Posts: 87 Joined: 24-May 08 From: Tacoma, WA Member No.: 9,100 Region Association: None |
The 8W1v2-4 looks like it's a perfect match for the box, though it's not part of the W3 series that you're looking for: http://www.crutchfield.com/App/Product/Ite...ofer&tp=111 # 8" 4-ohm subwoofer # metallic-finish polypropylene cone with nitrile-butylene rubber surround # power range: 35-150 watts RMS # peak power handling: 300 watts # frequency response: 28-250 Hz # sensitivity: 83.86 dB # top-mount depth: 3-13/16" # sealed box volume: 0.375 cubic feet No thanks, I'm sticking with dual voice coils. If I can't get a W3 to work, I'll look at other brands that have an 8" DVC speaker that will. But the more I look at the spec sheet and enclosure requirements on the JL Audio site, the more I'm pretty sure an 8W3 will work. It has the proper mounting depth, volume requirements, etc. The only thing that might not work is if the MDF used isn't thick enough (if the box was designed for a 50watt SVC speaker, there wouldn't be any point in using beefy MDF). That wouldn't be a design problem though, just special order the box with thicker wood. The 8W3v3 only needs 0.30 cubic ft of volume while the 8w1 needs 0.375... weird. The 8w3v3 does need more mounting depth, but still less than the specs Morph posted. Should be good. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:15 AM |
