Got Silicone Grease???, Do you lube your wheel lugs? |
JeffBowlsby |
Jan 2 2004, 10:38 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Volume 6, page 4.1-2/1 (where did these germans ever learn to number pages (IMG:style_emoticons/default/laugh.gif) ?) of the factory manual says under 'Wheel Change':
"Observe the following: 1. Coat ball surfaces of wheel bolts with an MoS(sub2) paste. (Type 914/6 has wheel nuts.)" What is this paste? I have heard previously it is silicone grease. Is that correct...I am not a chemistry guy... Not that I would ever buy any, much less look for any in the stores... (IMG:style_emoticons/default/wink.gif) but just on a whim...I went looking for 'silicone grease' at FLAPS. They had wheel bearing grease, synthetic grease, white (lithium) grease, red grease...but no silicone grease. When ever I have removed wheel lug bolts from my alloy Fuchs or Mahles, the bearing surfaces of the bolt and wheel are shiney...so there must be movement there. Does anyone else use a wheel lug lube like the factory manual commands? What kind, brand name, why, and where to get it...? Woulnt the lube prevent a necessary binding action (torque) between the bolt(nut) and wheel, potentially causing wheel loss? I know the lube goes on the bearing surfaces...not on the threads... Your thoughts...esteemed colleagues... |
kdfoust |
Jan 3 2004, 01:23 PM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
QUOTE(TimT @ Jan 3 2004, 06:19 AM) Anti-sieze, copper or graphite based, you can use either just use sparingly. A dab the size of a small booger on the threads is fine. Using more doesnt do anything better except make a bigger mess. Wont give false readings on a torque wrench, most torque values are for threads with some sort of lube on the threads. (IMG:style_emoticons/default/mueba.gif) Um, you sure about that? I seem to remember that torque specs are developed with dry fasteners. The torque is the torque. Lubrication (especially grease) on threads significantly impacts the tension applied to a bolt for a given torque level. Have fun, Kevin |
Lo-Fi Version | Time is now: 11th June 2024 - 05:15 AM |
