nice werk lymie |
nice werk lymie |
scotty b |
Jun 21 2008, 08:13 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Thought you guys might get a kick out of this. The underside of the hood on the Ferrari kit I'm werking on had a few knots in it. I start sanding away expecting to hit either an air pocket in the glass or just a mound of resin. WELL what I find is indeed a pocket in the glass. but what is IN the pocket is the kicker. It appears to be f-in tile mastic ! You can even see the trowel marks in it !! If anyone on the fiberglass business can tell me what this is all about I'd LOVE to know (IMG:style_emoticons/default/blink.gif)
Attached image(s) |
Jeff Hail |
Jun 22 2008, 03:25 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Thought you guys might get a kick out of this. The underside of the hood on the Ferrari kit I'm werking on had a few knots in it. I start sanding away expecting to hit either an air pocket in the glass or just a mound of resin. WELL what I find is indeed a pocket in the glass. but what is IN the pocket is the kicker. It appears to be f-in tile mastic ! You can even see the trowel marks in it !! If anyone on the fiberglass business can tell me what this is all about I'd LOVE to know (IMG:style_emoticons/default/blink.gif) It's closed cell pour foam. I have used it extensively in body panels and props. Primary use is in the boat hull industry for Coast Guard floatation requirements. It allows thinner mat layups and thickens the panel over straight mat and resin also enhancing rigidity. It does require a tool to spread it out in large surface areas so a trowel used wouldn't surprise me. If the non exterior surface is a little wavey it is PF. |
scotty b |
Jun 22 2008, 03:30 PM
It's closed cell pour foam. I have used it extensively in body panels and props. Primary use is in the boat hull industry for Coast Guard floatation requirements. It allows thinner mat layups and thickens the panel over straight mat and resin also enhancing rigidity. It does require a tool to spread it out in large surface areas so a trowel used wouldn't surprise me. If the non exterior surface is a little wavey it is PF. AH HA !! Sometimes I think there is someone from EVERY possible field on this board. (IMG:style_emoticons/default/biggrin.gif) |
type47 |
Jun 22 2008, 06:56 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
AH HA !! Sometimes I think there is someone from EVERY possible field on this board. (IMG:style_emoticons/default/biggrin.gif) so... did you have a question about cold fusion? go ahead and ask me (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:56 AM |
