Where's the temp sender?, '74 1.8 |
Rav914 |
May 31 2008, 07:16 PM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Sorry for the ignorance, the Haynes manual didn't say nor could I find it in the search.
I bought a new VDO guage for the center console to replace the non-working (I think) old guage. The new guage is right from the box so I'm assuming it's a working product. The needle on it too doesn't move off zero. So I'm assuming (that word again), it's the sending unit. But I don't know where it is and staring at the engine for 15 minutes didn't help either. Thanks! Nate |
914Sixer |
May 31 2008, 07:50 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
More than likely, your wire from the sending unit on the bottom of the engine is missing or melted into. Next, check to see if it is plugged in to the wiring harness by battery area. Probably one or the other. By the way the later unit uses a different sending unit.
orange914 |
Jun 26 2008, 10:11 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
More than likely, your wire from the sending unit on the bottom of the engine is missing or melted into. Next, check to see if it is plugged in to the wiring harness by battery area. Probably one or the other. By the way the later unit uses a different sending unit. do you know what color the wire is (harness side) any pictures mike |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:38 AM |
