| Wilhelm |
Jun 28 2008, 05:23 PM
Member ![]() ![]() Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
Had some time and bronze extrusion so thought I would try my hand at making some trailing arm bearings. Hopefully these will eliminate the "striction" (sticky friction of synthetic bearings). The ID is 28mm, the OD is 38mm, the flange diameter is 52mm, the flange width is 6.3mm, the overall length is 55mm. To do list: cut an oil groove midlength and crossdrill into this. After pressing these in will drill and thread a grease zerk to intersect the oil groove.
| r_towle |
Jun 28 2008, 10:31 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Two hardened washers per side with a thrust bearing in the middle...simple.
Yes you need to grease it..big deal. Rich |
Wilhelm Bronze Trailing Arm Bearing Jun 28 2008, 05:23 PM
Racer Chris My Delrin bushings don't have "striction... Jun 28 2008, 05:39 PM
Wilhelm
My Delrin bushings don't have "striction... Jun 28 2008, 07:48 PM
So.Cal.914
My Delrin bushings don't have "strictio... Jun 28 2008, 08:59 PM
Wilhelm
Attachments are working now.
Don't know ... Jun 28 2008, 07:39 PM
J P Stein Some things you should be aware of:
The ID of the... Jun 28 2008, 09:50 PM
Wilhelm
The ID of th... Jun 28 2008, 10:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 06:43 PM |
