| nycchef |
Jun 29 2008, 03:49 PM
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
have been trying to fix my horn, after 10 tries i think i damaged the wire that goes thru the steering column. i used to be able to touch it to the nut that holds the steering wheel on and it would work. no more. the wipers are fine so i am asuming it ain't the fuse. whats the best way to change the wire?
| r_towle |
Jun 29 2008, 05:00 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
There are three connectors from what I recall when taking these things apart.
If I used a word that may be incorrect, my apologise, but Damn there are three connectors, three plugs, just under the lower kneepad that connect all the electrics to the steering wheel, ignition switch, horn, blinkers, high beam/low beam etc. So my statement "the connectors at the base of the steering column" is correct. it does not need to be disputed. While you have been tugging and pulling, you may have dislodged the wire from the connector/plug that feeds the horn wire.. So, check it with a meter to make sure its still connected. Rich |
nycchef horn wire Jun 29 2008, 03:49 PM
r_towle Check it with a meter...see if its broken or pulle... Jun 29 2008, 04:20 PM
Cap'n Krusty There is no "connector at the base of the col... Jun 29 2008, 04:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th October 2026 - 06:28 AM |
