> Need some opinions, for this....
toon1
post Jun 30 2008, 08:20 PM
I am creating a mold for an air intake scoop that will mount on the B pilliar.
My intention is to keep things close as possible to the stock look. I also wanted something that I could remove if need be( that's why I decided not to go with fender scoops).
With this preliminary setup( pictured), I am not sure if it will scoop enough air. it stands off about 2" from the pilliar.
The other option is to make the outside somewhat round, similar to the top scoops of a Bugatti.
I'm also open to all other ideas.
Thank's, Keith
toon1
post Jul 1 2008, 01:45 PM
QUOTE(ericread @ Jul 1 2008, 12:16 PM) *
I'm not really sure if I like the looks or not. My real question is how much air you expect to move into the engine compartment? And I guess, why? I follow Jake Raby's threads pretty close, and his experience seems to demonstrate that a properly running 914 really shouldn't have a cooling problem. Are you trying to correct some cooling problem, or is this more of a project you thought would be cool?
If it's a project for fun, then it's nobody's damn business how it looks (but then again, you did ask (IMG:style_emoticons/default/idea.gif) . That's your decision. But if it is to correct a cooling problem, I would be very interested in learning more about your perceived problems.
Eric Read
I don't have any cooling related issues. I thought it would be a neat project to see if it helps to stablize the temps under load. I do see the CHT's rise on occasion under certain conditions. I thought this might help.
Yes I did ask, so I opened myself up to critisizm. Fire away!
Unless I hear solid evidence that it doesn't help, I will make them dispite what people think. If they don't help, they will be easy to remove, nothing lost nothing gained.
I posted this incase there where other people with the same idea but haven't done it yet.
ericread
post Jul 1 2008, 03:21 PM
The Viper Blue 914
QUOTE(toon1 @ Jul 1 2008, 12:45 PM) *
Cool! I'm interested in what you find out. Obviously, air will only be directed to the engine at speed. With the tin in place, I wonder how you will direct the air stream to be efficient. Without the tin, I believe you will have a cooling problem at any speed. The again. if you just direct the air stream to the engine compartment, then I don't see it being as a help. Inject the air into the tin on both sides of the engine?
What are your thoughts?
Eric
toon1   Need some opinions   Jun 30 2008, 08:20 PM
r_towle   Try naca ducts in the rear of the rocker panel wit...   Jun 30 2008, 08:22 PM
SirAndy   how are you going to get the air to the engine? :...   Jun 30 2008, 08:23 PM
Rusty   Hi Keith, This idea has been tried before, with s...   Jun 30 2008, 08:26 PM
toon1   Try naca ducts in the rear of the rocker panel wi...   Jun 30 2008, 08:50 PM
Dr. Roger   finally found a pic similar to what we were talkin...   Jul 1 2008, 01:43 AM
tdgray   My .02.... don't do it... looks like :stromber...   Jul 1 2008, 10:35 AM
toon1   My .02.... don't do it... looks like :strombe...   Jul 1 2008, 12:51 PM
URY914   What is the intent here? -To add cooling to the ...   Jul 1 2008, 01:02 PM
toon1   What is the intent here? -To add cooling to the...   Jul 1 2008, 01:11 PM
ericread   I'm not really sure if I like the looks or not...   Jul 1 2008, 01:16 PM
toon1   I'm not really sure if I like the looks or no...   Jul 1 2008, 01:45 PM
ericread   I don't have any cooling related issues. I...   Jul 1 2008, 03:21 PM
Dr. Roger   Another thought. Instead of bring the entire sail...   Jul 1 2008, 03:14 PM
carr914   I always wanted to do this, but never have. T.C. ...   Jul 1 2008, 03:28 PM
tdgray   Looks wise ... hate it. Functionality wise... I d...   Jul 1 2008, 03:44 PM
toon1   Another thought. Instead of bring the entire sai...   Jul 1 2008, 04:41 PM
Dr. Roger   but I've got to admit, with that big vacuum ju...   Jul 1 2008, 04:43 PM
SirAndy   with that big vacuum just behind the cockpit, tha...   Jul 1 2008, 06:13 PM
Zardozz   I've been kicking around an idea like this for...   Jul 1 2008, 05:43 PM
Sleepin   What about a roof scoop ducted through the roof an...   Jul 1 2008, 06:40 PM
toon1   Here's a pic. of what I added to get air into ...   Jul 1 2008, 09:40 PM
orange914   keith we got that stripped targa top if you want t...   Jul 5 2008, 10:07 PM
- Lo-Fi Version Time is now: 31st July 2025 - 05:30 PM
