914 6 with cis?, what r the paritculars? |
echocanyons |
Jan 3 2004, 06:11 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I am prolly goin to pick up a 2.7 with CIS, I am not sure if I know of a 914 running this.
Help me out on what it'll take to get this done. |
ArtechnikA |
Jan 4 2004, 08:46 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(echocanyons @ Jan 3 2004, 09:05 PM) What fuel pump should be utilized? Stock 914/4? I wonder if the engine could be mounted an inch or so lower? So S cams wont work with this I noticed on Web-Cam's site they had a special grind for the 2.7 but they are spendy you need a CIS fuel pump. CIS runs at about 60 psi and i don't believe the /4 pump can handle both the pressure andthe required volume. the CIS filter is also substantially different - CIS is VERY sensitive to water in the fuel and the filters are designed to trap and retain water - in addition to being metal-cased to contain the pressures. i haven't looked at WebCam's site, but figure about $1000/pr for 911 cams. more if you need to change to 4-bearing cam towers, yet more if you need to use pistons with adequate valve reliefs... i have seen a conversion /6 with the engine mounted lower for this very issue ... (the Bradster had one...) |
Lo-Fi Version | Time is now: 6th June 2024 - 02:38 PM |
