| LowGT |
Jul 1 2008, 07:16 PM
1.8 and Proud! ![]() ![]() ![]() Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
I'm in the process of re-sealing a 74 1.8 and after taking off the cooling fan I see one blade is broken and gone. Is this going to throw everything out of whack, or is one missing blade negligible?
Second, the thermostat is shot and has no cable. Normally this wouldn't concern me since the flap should fail to the safe UP position. However, after removing the tin I found the flapper was locked down over the oil cooler by the lower tin piece. I took everything apart because of fuel vapor lock and the engine getting sluggish after driving for a while, so I was concerned about cooling issues. Other than that the car was running fine. Should I be worried about any serious complications? Dan |
| Pat Garvey |
Jul 1 2008, 07:30 PM
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
I'm in the process of re-sealing a 74 1.8 and after taking off the cooling fan I see one blade is broken and gone. Is this going to throw everything out of whack, or is one missing blade negligible? Second, the thermostat is shot and has no cable. Normally this wouldn't concern me since the flap should fail to the safe UP position. However, after removing the tin I found the flapper was locked down over the oil cooler by the lower tin piece. I took everything apart because of fuel vapor lock and the engine getting sluggish after driving for a while, so I was concerned about cooling issues. Other than that the car was running fine. Should I be worried about any serious complications? Dan The missing blade on the fan(where did it go?) will make things unbalanced. Bearings will eventually fail. Get another. Get another thermo and cable. Make it right. Pat |
| LowGT |
Jul 1 2008, 07:40 PM
The missing blade on the fan(where did it go?) will make things unbalanced. Bearings will eventually fail. Get another. Get another thermo and cable. Make it right. Pat Hell if I know where it went (IMG:style_emoticons/default/biggrin.gif) , I didn't find it anywhere after taking the rest of the engine apart. I definitely plan on replacing the thermostat/cable and making sure the flappers are working. I'm more concerned if any damage may have been done with the flapper being locked down over the oil cooler by the lower tin. I was on the fence about replacing the fan, but I'm definitely going to do it now. |
LowGT Broken fan blades, and thermostat/tin question. Jul 1 2008, 07:16 PM
davep Jake makes sure his balanced assemblies even have ... Jul 1 2008, 07:26 PM
kwales Look in the fan shroud for the missing blade.
Fou... Jul 1 2008, 07:35 PM
Jake Raby One blade is good for a 4 gram differential in bal... Jul 1 2008, 08:24 PM
zymurgist
One blade is good for a 4 gram differential in ba... Jul 2 2008, 06:07 AM
type47
On another car site that I used to frequent, this... Jul 2 2008, 07:30 AM
zymurgist
On another car site that I used to frequent, thi... Jul 2 2008, 01:58 PM
type47
[quote name='type47' post='1051699' date='Jul 2 2... Jul 2 2008, 02:26 PM
zymurgist
fix what ya got, sell it before you replace it... Jul 2 2008, 02:35 PM
Second, the thermostat is shot and has no cable. ... Jul 1 2008, 08:29 PM
james2 It's obvious that the rodent in your avatar ca... Jul 2 2008, 04:34 PM
LowGT
It's obvious that the rodent in your avatar c... Jul 2 2008, 08:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2026 - 06:58 PM |
