| rhodyguy |
Jul 1 2008, 05:47 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
started with the carb linkage and worked my way forward. shot bushings for the cable pivot arm. sloopy and binding. no time to rebush/finish the assem before a week from friday. had a better bushed pedal assem on hand that has sume surface but good shaft bushings with little to none side slop. an oil eater soak, some brake cleaner, and a wire brush. i'll do a quick Mar-hyde treatment for the rust, arrest the small ammount under pedal base and rattle can it with some Zero-rust. i have a rebush kit for the one i took out and will rebuild it at a later date. i have a new cable, might as replace the old one while i'm in this deep. more pictures as i go along.
| rhodyguy |
Jul 2 2008, 12:52 PM
the Marhyde converts the rust to a sandable, paintable surface.
Zero Rust is a great rattle can paint. i used it when i did my front suspension. wears like iron and any touch up is a squirt away. don't expect krylon pricing. think eric shay uses Zero Rust on some of the items he carries. i listened to you rich. dug out the bushing kit and will use the 2 for the throttle pivot. thanks for the push! Attached image(s)
rhodyguy a screeching groan everytime i pushed on the gas Jul 1 2008, 05:47 PM
r_towle just rebush the accel piece on the pedal assembly.... Jul 1 2008, 09:12 PM
championgt1 Stopped by Kevins house on the way home. A little ... Jul 1 2008, 09:15 PM
LarryR Its just your cars audible protest to the current ... Jul 1 2008, 09:21 PM
Demick
Its just your cars audible protest to the current... Jul 2 2008, 09:29 AM
championgt1 :rotfl: Jul 1 2008, 09:27 PM
Zundfolge You've got carbs eh? So what does the carb end... Jul 2 2008, 01:42 PM
ericread Any chance you got a cat caught in there??? :ang... Jul 2 2008, 02:32 PM
rhodyguy btw. before you invest a bunch of time cleaning up... Jul 3 2008, 08:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 08:05 PM |
