| LowGT |
Jul 1 2008, 07:16 PM
1.8 and Proud! ![]() ![]() ![]() Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
I'm in the process of re-sealing a 74 1.8 and after taking off the cooling fan I see one blade is broken and gone. Is this going to throw everything out of whack, or is one missing blade negligible?
Second, the thermostat is shot and has no cable. Normally this wouldn't concern me since the flap should fail to the safe UP position. However, after removing the tin I found the flapper was locked down over the oil cooler by the lower tin piece. I took everything apart because of fuel vapor lock and the engine getting sluggish after driving for a while, so I was concerned about cooling issues. Other than that the car was running fine. Should I be worried about any serious complications? Dan |
| james2 |
Jul 2 2008, 04:34 PM
Member ![]() ![]() Group: Members Posts: 97 Joined: 28-June 08 From: Georgia Member No.: 9,225 Region Association: None |
It's obvious that the rodent in your avatar caused this problem. You might look into getting a smaller hamster, they are easier on the fan blades....IMHO
I'm in the process of re-sealing a 74 1.8 and after taking off the cooling fan I see one blade is broken and gone. Is this going to throw everything out of whack, or is one missing blade negligible? Second, the thermostat is shot and has no cable. Normally this wouldn't concern me since the flap should fail to the safe UP position. However, after removing the tin I found the flapper was locked down over the oil cooler by the lower tin piece. I took everything apart because of fuel vapor lock and the engine getting sluggish after driving for a while, so I was concerned about cooling issues. Other than that the car was running fine. Should I be worried about any serious complications? Dan |
| LowGT |
Jul 2 2008, 08:44 PM
It's obvious that the rodent in your avatar caused this problem. You might look into getting a smaller hamster, they are easier on the fan blades....IMHO I tried a direct meth injection kit on the hamster, the ebay add stated it was completely safe and good for an extra .25 whp. However, I don't think the fan could support the shock load the hamster put out. (IMG:style_emoticons/default/idea.gif) |
LowGT Broken fan blades, and thermostat/tin question. Jul 1 2008, 07:16 PM
davep Jake makes sure his balanced assemblies even have ... Jul 1 2008, 07:26 PM
Pat Garvey
I'm in the process of re-sealing a 74 1.8 and... Jul 1 2008, 07:30 PM
LowGT
The missing blade on the fan(where did it go?) w... Jul 1 2008, 07:40 PM
kwales Look in the fan shroud for the missing blade.
Fou... Jul 1 2008, 07:35 PM
Jake Raby One blade is good for a 4 gram differential in bal... Jul 1 2008, 08:24 PM
zymurgist
One blade is good for a 4 gram differential in ba... Jul 2 2008, 06:07 AM
type47
On another car site that I used to frequent, this... Jul 2 2008, 07:30 AM
zymurgist
On another car site that I used to frequent, thi... Jul 2 2008, 01:58 PM
type47
[quote name='type47' post='1051699' date='Jul 2 2... Jul 2 2008, 02:26 PM
zymurgist
fix what ya got, sell it before you replace it... Jul 2 2008, 02:35 PM
Second, the thermostat is shot and has no cable. ... Jul 1 2008, 08:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2026 - 05:40 PM |
